Results 261 to 270 of 474
09-07-2017, 01:14 PM #261Z tower endstop offset in the Eeprom settings round off to the nearest number.
Have yet to mess with that kind of thing. No the the first clue where that lot is.
Given that it never actually probes anywhere but three points on the outer rim - i there actually any point in doing a topographical 'level' with so few points ?
First test corner piece came out perfect :-)
Strut is snug as a bug in a rug !
09-08-2017, 06:54 AM #262
I'll give that a go when I'm not printing something.
cheers
Got me calculations way off for the first cornerpiece.
Ended up with internal angle of 120. So currently printing - hopefully - a 60 :-)
Next need to work out where the belts are going to go.
09-08-2017, 10:35 AM #263
Corner piece comparison: 30x30 struts for the Big Bastard versus 20x20 on the he3d k200.
And yes i know the holes don't line up on that corner piece- they will on the next one :-) Why they're called - 'test pieces'
Have to admit, till I did a direct comparison just now - I hadn't realised just how much larger the 30x30 is :-)
Cue manic laughter: 'hahahhahahhaha !!!!!! She going to be a monster !'
09-08-2017, 03:12 PM #264
these are just test peices.
Each one is currently different :-)
The third one will have wedge shaped rails for the horizontal struts.
Just to lock them into place. 2 Bolts each side ought to do it.
Might end up with more - depends if I have to make the base much bigger. Still not convinced the struts are long enough.
Looking at build plate I reckon I can extend each side by at least another 10 cm if necessary.
Mind you once you stick a couple struts into the corner pieces it looks pretty big :-)
The vertical strut does not need anything else. I have to hammer it in and out. This flashforge pla is tough stuff. I had some aluminium powder come out the last time - pla isn't scratched at all :-)
Been banging it on the floor to get it in and against the underside of the table to get it out.
Need a rubber mallet :-)
first 2 printed at 100mm/s - thought I'd do the 3rd one at 150 - just to see if it's still dimensionally accurate. Plus it cuts the print time down to 1 hour :-)
Meanwhile using flsshforge to make some 30x30 strutnuts :-)
Sorted :-)
Lock really nicely in place and can be tightened pretty much as much as the metal ones.
These use nuts for 3mm bolts - not sure if 4 mm nuts would be too big.
I'll see :-)
Nope - nuts don't physically fit the 6mm channel.
No problem I have a lot of of 3mm nuts and my local hardware store does well cheap different length 3mm bolts.
Given that these are sized for 30mm extrusion - not going to bother posting the stl. If anyone wants it - pm me :-)
They're actually better than the strutnits meant for the 2-x20 as they fill the slot and give a lot more surface area to grip with.
I'll see if I can break one.
Yep. Left a fairly deep gouge in the aluminium mind you.
I'll use the metal ones for structural joining. These will be fine for anything not under a lot of stress.Last edited by curious aardvark; 09-08-2017 at 04:41 PM.
09-09-2017, 06:36 AM #265
09-09-2017, 09:11 AM #266
Houston - we have a problem.
The glass disc is the unused 200mm glass bed from the k200 - just for a bit of perspective :-)
The cardboard is 370mm - which once you add 10mm for bolts to the 350mm print area - is the size the aluminium plate will be.
somewhere down the line I bogged the maths up (are we surprised ? didn't think so :-).
Corner piece redesign I reckon.
Looks like If I make them a bit wider, it should do the job. Although making the strut holders longer would be a lot easier. I'll try that first.
I will measure it - but hey, I did that last time.
doh !
Oh yeah made a bunch of strutnuts:
added 45mm to length of struts - basically lining struts up with end of corners adds 45mm and is bang on size wise. So extrusion should have been 460 not 415.
Oh well, plastic cheaper than aluminium and there will be an aluminium baseplate as well. So it's not losing anything structural integrity wise. Right hope the new corner piece fits the printer bed.
Yep - and the 150mm/s print was just as good as the 100 and 75's - so that's good :-)
More once I've printed the new corners.Last edited by curious aardvark; 09-09-2017 at 09:59 AM.
09-10-2017, 04:56 AM #267
Calculation wise I just scaled up from alexa. 1.7 something I think it was.
Would have been better making a cardboard mockup first. Or finding out if there was a standard calculation already online somewhere.
Well we live and learn :-)
given how much cornerpiece there now is, plenty space for the belts.
Hell, all it needs is a crosspeice and a hole - the crosspiece will further reinforce the corners as well. Can get them pretty close to the uprights without any problems.
Need to do the carriages first, I think.
Bought some £10 kg filament a few weeks back, that was supposed to ship from the uk. No sign of it, so presumably it's on the slow boat from china. A lot of amazon suppliers lie through their teeth about stuff like that ;-)
Shame as I'm running out of flashforge filament. Mind you, plenty of other stuff lying around.
Sliced the larger corner for the flashforge last night: 60mm/s - reckoned 6hours 54mins. Given that alexa knocks them out at 1 hour 48, didn't bother doing one on geraldine lol
So that's the right size.
Now need to move the upright sockets inwards and reshape the cornerpieces.
I'm getting there, slowly :-)Last edited by curious aardvark; 09-10-2017 at 09:52 AM.
09-10-2017, 11:12 AM #268
So I ended up with this:
Somehow the non-rounded corners make it look more industrial - or maybe that's just me :-)
Anyway it will keep the sturts the right distance, while having the upright a lot nearer the horizontals (see, I do listen ;-)
It's also 40gms lighter, hour 23 print time. I also made the upright socket a half mm larger in both directions. Primarily because it's cold and wet out there and I can't be arsed to go all the way down the garden to get the rubber mallet out of my shed :-)Last edited by curious aardvark; 09-10-2017 at 11:21 AM.
09-11-2017, 06:13 AM #269
given the sheer heavidutiness (yeah it's a word) of the 30x30 struts and corner pieces and the fact that I'll have reinforcing bars about 2/3 of the way up (also necessary for the control panel if the printer is on a desk) and an aluminium plate on the base. Also the commercial units will have a top aluminium plate as well. The BB will have a plywood top, so I can move stuff around easily.
Definitely only need one set of horizontals.
Don't forget, all the gear: steppers, psu, motherboard, will be top mounted.
Probably go for a side mounted filament holder, you won't want to stand on a chair to do it.
The only thing going at the bottom is the heated bed, which will be manually adjustable. After the recent threads - going to avoid topographical mapping completely. It's definitely not necessary as long as you have an adjustable bed.
Until I get the cupped magnets and wheels and pulleys - don't know how big the carriages will be - so won't finish the corner pieces with the pulley until I get those.
It does mean I'll need to print an extra set of corner pieces - but at 480 grams a set - I can live with that.
Finally found some decent priced wheels last night. Sets of 9 - so bought 2 - came in at £6.80 - so about 38p a wheel (under 50 cents).
White with bearings.
Haven't decided on final colour scheme yet - but probably go with white pla as it contrasts well with the silver aluminium. Plus it's really hard to see the print lines of white pla :-)
Or I might go with black - or red.
I don't really do colours lol
Currently contemplating whether to buy a set of metal nema 17 brackets or print plastic cages.
Probably go for the metal, for longevity. Plus they aren't exactly expensive.
Cost is currently at £270 and I think, just the printbite (and motor brackets) to go. Though I am also thinking about a volcano hot end with gears.
But should still come in under the £350 mark and that's with upgrading almost everything compared to the k200.
I'll get the frame up this week and cut the top board and maybe get the aluminium cut as well.Last edited by curious aardvark; 09-11-2017 at 08:10 AM.
09-11-2017, 08:10 AM #270
So I can actually fit 2 of the new cornerpieces on alexa at one print - 3 hours at 150mm/s.
And one on the flashforge at 3 and a half hours at 65mm/s.
Looks like the 0.5mm nozzle also helps a bit too :-)
Got them down to 67gms.
