Results 3,451 to 3,460 of 4110
10-02-2016, 07:50 PM #3451
- Jun 2016
- Oklahoma
- 904
For one, the holes that the bed adjusting screws go down through are a fair amount larger than the screws. This will let the whole platform twist or move slightly laterally. If you don't adjust the Z shim so the springs really compress there is not a lot of tension on the bed. Also the end of the platform that holds the bed can twist quite easily.
So one remedy was to go with bigger screws which meant drilling out the bed and enlarging the counter sink to accommodate them. No thanks.
So the solution was to come up with some kind of bushing for the hole to reduce lateral movement of the bed. While doing that I decided that if I expanded it and bolted it to the bed it might stiffen it a little also.
So far it is working nicely.
It was along the idea of changing out the Z rods for larger ones. The stiffer you get the whole traveling bed the less lateral movement and less chance for layer shift. Especially on larger, heavier parts.
10-02-2016, 07:59 PM #3452
My weekend project. It is for my hot ends with Microswiss parts. Decided to mold some silicon covers for them. This is the 4 up mold.
https://goo.gl/photos/JXeEfmY7XMuDguPU8
10-02-2016, 08:26 PM #3453
- May 2016
- Annapolis, MD
- 523
10-02-2016, 11:30 PM #3454
10-03-2016, 06:02 AM #3455
- Jun 2016
- Oklahoma
- 904
10-03-2016, 09:48 AM #3456
Not too bad for first try. Had 2 of the 4 fail, must not have got the 2 parts mixed good enough.
10-03-2016, 10:07 AM #3457
- May 2016
- Annapolis, MD
- 523
10-03-2016, 10:30 AM #3458
It is a Smooth-On brand product called Mold Max 60. It is their only high heat product. It is good for up to around 295c.
10-03-2016, 11:52 AM #3459
- Jun 2016
- Oklahoma
- 904
10-03-2016, 01:14 PM #3460
- Feb 2016
- 360
New member with print issue
