Results 1,971 to 1,980 of 4110
06-24-2016, 06:48 PM #1971
- Feb 2016
- 360
It's really personal pref.
I design in MM as that is native for both the machine and S3D.
Actually I design in meters, because I use Blender...and for some reason when Blender exports to .stl it converts 1m to 1mm. At first I hated it, but very quickly grew to love it. I can work on TINY stuff, without the usual mucking about with the camera and zoom.
06-25-2016, 10:39 AM #1972
- Jun 2016
- Oklahoma
- 904
I have created a Facebook group called QIDI 3D. It is a closed group for fans of these printers and 3D printing to discuss and share.
Feel free to join and get content and discussions started!Last edited by wirlybird; 06-25-2016 at 11:12 AM.
06-25-2016, 01:37 PM #1973
- May 2016
- Annapolis, MD
- 523
Does anyone with a QIDI have speed control over their blower fan's RPMs? I seem to get full speed no matter what I request. Is this SW, the QIDI controller HW or FW, or the fan?
06-25-2016, 02:29 PM #1974
- Aug 2014
- 627
This is something I really hated coming from a Marlin setup because you can't control the fan speed outside of an actual print job and the control panel is worthless as it is off or on and never by how fast.
My fan did change speeds because I could hear its pitch change as the layers went up (I had it get progressively faster at 40%, 60%, 80% depending on the layer and bridges was at 100% but I never printed a long bridge with it to know if that changed or not. Oh, and I had blip checked).
Do this test on a print job: Fan speed 10% layer 2 then layer 3 100% and see if the pitch changes.
06-25-2016, 02:58 PM #1975
- May 2016
- 55
I use mm in Lightwave 3D. I've mainly been modeling parts that have to fit together, and it helps to work out tolerances in the machine's native unit. It can be tricky at times, regardless. Sometimes a part will behave differently if you print it upside down, because whatever's on the bottom will flatten out. And of course, putting something on a different axis can affect how it fits. I try to get all of the bits that go together on the same axis whenever possible.
06-25-2016, 03:40 PM #1976
- Jun 2016
So I've been suddenly getting a lot of clogged nozzles. Took apart and cleaned. Printed one part, clogged again. I think it's the PLA.
But I'm wondering, has anyone tried the Twinclad XT nozzles that are $15/ea? Do they cut down on issues at all if you happen to have less-than-stellar filament?
Also, I have a newer Qidi (10mm Z rods), would this be an MK10 Extruder? Is there any way to tell without disassembly and measuring the nozzle thread? I've seen both MK8/10 mentioned in this thread and Qidi sells nozzles for both - so I assume they switched at some point.
I think it's an MK10 based on the PTFE inner going deep into the nozzle.
06-25-2016, 04:04 PM #1977
- Aug 2014
- 627
06-26-2016, 07:54 AM #1978
- May 2016
- 6
Hello guys,
I'm having a problem with the printer, it seems the stepped motor cable for the X Axis is not working anymore, and I have to substitute that.
To do that, I have to remove some nuts. Point is, 5mm hex keys do not fit (the nut is bigger), and 6mm hex keys is tto wide.
Does any of you know the size of these nuts? Are the fraction-of-inches nuts?
That you in advance!
06-26-2016, 08:45 AM #1979
- Jun 2016
- Oklahoma
- 904
06-26-2016, 08:46 AM #1980
- Jun 2016
- Oklahoma
- 904
