Results 1 to 10 of 15
Thread: The Ester - DIY SLS 3D Printer
10-02-2014, 02:33 PM #1
I like this soo much. Finally some transparency from someone that's built one of these machines.
10-02-2014, 07:48 PM #2
11-17-2014, 04:05 PM #3
Brandon (I assume you are Brandon),
Typically SLS printers have a very hot build chamber (essentially an oven), where the constant temperature is just below the temperature required to sinter the material. I may be wrong about this, but in the video, it looks like there is no heated chamber. Is this possible because of the material being used, or have you discovered the heated chamber is unnecessary?
- Mike
