Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Administrator Eddie's Avatar
    Sep 2013
    Cape Coral, FL
    Follow Eddie On Twitter Add Eddie on Facebook Add Eddie on Google+ Add Eddie on Shapeways Add Eddie on Thingiverse
    The Ester - DIY SLS 3D Printer
    Brandon Fosdick is an Aerospace Engineer, but his true interest lies in 3D printing. He realized that there are no affordable SLS based 3d printers on the market, so he set out to create his very own, called the Ester. It uses polyester powder and a laser to sinter the material and build up 3D objects. While he is still in the developmental process, if all goes as planned he may launch a crowdfunding campaign to raise funds for further development. What do you think? Will a printer like this succeed?
    Read more at: http://3dprint.com/17570/affordable-sls-3d-printer/
    I like this soo much. Finally some transparency from someone that's built one of these machines.
    Quote Originally Posted by repkid View Post
    Thanks!
    This space intentionally left blank
    Technician wpilgrim's Avatar
    Mar 2014
    Mississippi
    Follow wpilgrim On Twitter Add wpilgrim on Facebook Add wpilgrim on Thingiverse
    I am really happy to see this, I will be following his progress. Thanks for the info.
    Awesome!
    What is the polyester that you settled on? Was it difficult to find?
    If you plan to do a kickstarter program I'd be very interested in the printer
    Student Mike's Avatar
    Dec 2013
    Phoenix
    Brandon (I assume you are Brandon),
    Typically SLS printers have a very hot build chamber (essentially an oven), where the constant temperature is just below the temperature required to sinter the material. I may be wrong about this, but in the video, it looks like there is no heated chamber. Is this possible because of the material being used, or have you discovered the heated chamber is unnecessary?
    - Mike
  8. #8
    Hi Mike,
    You're correct in that the build chamber isn't currently heated. I'm reserving that as an option for later on, but so far I've managed without it.
    It turns out that the heated chamber is useful, but not quite as necessary as it's been made out to be, depending on the material and the particular part being printed. And of course, there are other ways of getting the same effect. In fact I've found that shining a desk lamp on the powder surface can work just as well. I'm currently looking into adding IR LEDs to the underside of the carriage to see if that works too. These are all things that still need to be explored, and I'm putting out Ester as a development kit so everyone can get in on the fun.
  9. #9
    Dec 2013
    Phoenix
    It sounds really cool, Brandon. I'm glad to hear you're doing this. Best of luck to you!
  10. #10
    Hello a development kit sounds like a lot of fun,one question why LED it doesn't give off much heat, it would have a coolness factor though
