Results 61 to 70 of 73
Thread: Diy it?
06-08-2016, 01:09 PM #61
- Jul 2014
- BC Canada
- 20
I'm still trying to find the most current version of the structural pieces in the git repository.
I printed the "all.dxf" file on the laser cutter last night and when I compared them to the assembly animation Rylan posted (page 3 of this thread), they are NOT the same!! These are possibly the "oil dampened version" as discussed in this thread.
In "PeachyPrinterHardware/peachy_production/" these files here appear to be the scanner.
In "PeachyPrinterHardware/peachy_printer/ there is a collection of SMC files that COULD be the right files but I can't open them to verify.
I know these SMC files were created by the Laser Cutter's software but what is that software and can I download it?? (Ok, Duh, it's "SmartCarve")
Are there DXF versions of these files somewhere?
Has someone found the most current files?
The laser cutter at my local MakerSpace uses RD Works (I'll be getting a copy soon). This outputs RDL files not SMC. I can not open them with RD Works :-(
helpLast edited by thej; 06-08-2016 at 01:21 PM. Reason: update
06-09-2016, 01:16 PM #62
- May 2014
- 60
Hey there, that repo is all old stuff, you want this one: https://github.com/PeachyPrinter/pea...terhardware1.0
Totally threw me for a loop at first to!
MOST of the items have .scad files for them. This is a format used by OpenSCAD, it's really just a text file containing a script that defines the object. I'm not sure about converting this to RD Works, I do know that it can output at least a .stl file.Last edited by oninoshiko; 06-09-2016 at 01:25 PM.
06-09-2016, 03:13 PM #63
- Jul 2014
- BC Canada
- 20
Thanks! I dug through those files before but I really didn't know what I was doing yet ! I will check them out again :-)
RD Works will take a DXF so converting the SCAD models to DXF will work just fine.
J
06-13-2016, 06:42 AM #64
- May 2014
The galvo works with an electro-magnet, a well modelled system can take that into account and compensate the inertia. Am I wrong? Certainly for faster speeds it gets tricky but looking at the current state it just looks way too slow. If the resin curing speed is not the issue then at least a 2x speed increase would be great if possible.
06-14-2016, 11:22 AM #65
- Mar 2016
- 68
Please read carefully what I typed before: it is a combination of factors: cost (laser diode prices increase substantially as they become more powerful, goal was a sub C$100 printer), curing time (the resin curetime is the main determining factor) and accuracy (if it takes x seconds to cure a layer either way, move slower as it increases accuracy)...
06-14-2016, 11:35 AM #66
- May 2014
Is there a datasheet for the resin?
06-14-2016, 11:41 AM #67
- Mar 2016
- 68
06-14-2016, 04:44 PM #68
- May 2014
- 60
You also need to concern yourself with the specific gravity, as it does have to float on the the saline.
06-14-2016, 04:57 PM #69
- Mar 2016
- 68
06-22-2016, 08:03 PM #70
- Sep 2013
- Saskatchewan, Canada
- 294
You'd probably want to contact makerjuce for that kind of info, as they were the ones making the peachy resin.
https://www.makerjuice.com/pages/contact-us
