Results 3,541 to 3,550 of 4110
10-10-2016, 10:02 AM #3541
- Feb 2016
- 360
Here is my door clips....super simple but work like a champ.
For cleaning PTFE tubes I would suggest getting the proper sized drill bit. The issue with using a hex-wrench is that it is different shape than the tube, you could potentialy deform the tube by cleaning it like that.
A drill bit is round like the tubes interior is supposed to be. Not to mention a brill bit is designed to remove material from a hole, the channels in the bit will help alot to that end.
10-10-2016, 07:28 PM #3542
- Sep 2016
- 80
Oh, by that point the PTFE tube had been removed and I still had plastic coming down from the metal throat and into the hot end.
I just didn't want to drill and end up scratching up the insides of the metal and thereby make things even worse.
10-10-2016, 08:46 PM #3543
- May 2016
- Annapolis, MD
- 523
10-11-2016, 04:27 PM #3544
- May 2016
- Annapolis, MD
- 523
Well, that was a rather dull interlude. Hope everything stays up.
10-12-2016, 10:12 AM #3545
- Oct 2016
I am having issues using my printer with simplify3d. Can anyone help me? I have the qidi tech printer and the test prints work. I can't get anything else to print not even downloaded finished projects. I posted a word doc with screenshots of my settings. anyone see anything wrong? I am saving to sd card as an x3g file.....Well The attachments are working for me so here come a bunch of screen shots. Sorry about the inconvenience and hopefully you can see them or download and review them. I also am posting a link so you can download the file in case the posted pics doesnt work because they are showing up as broken images. The link works. just click free user and it will have you confirm the download. Thanks!
Last edited by jfkansas; 10-12-2016 at 11:50 PM. Reason: Multi post - Please use better file transfer option. If you need to post pics there are plenty of online picture hosts
10-12-2016, 04:38 PM #3546
- May 2016
- Annapolis, MD
- 523
10-13-2016, 08:36 AM #3547
- Oct 2016
10-13-2016, 08:43 AM #3548
I believe there is a minimum amount of posts needed to enable picture posting. Also I think the image capabilities of the board are or were turned off.
It is easy to post pics on Imgur or Tinypic and link here. I dislike photobucket as it is ad heavy any more. I host most of my pics from a Google photo account and it works well.
10-13-2016, 06:43 PM #3549
What kind of issues are you having. Are they not printing at all or partially printing?
I have recently had issues with Simplify3D files when sending the gcode files to OctoPrint they fail but if I run the x3g file directly from the SD card they work fine. The same exact one.
Now that being said in Simplify 3D it outputs both the x3g file and gcode file at the same time. If the gocde file is accidentally being the one copied to the SD card that could be the issue as QIDI only prints x3g files from the card yet only gcode from OctoPi.
Editor in Chief
Bitsonline
10-13-2016, 06:54 PM #3550
Speaking on my issue with OctoPrint this is what is going on.
Once I save a file I normally send the gcode file to OctoPi and print. For some reason after what I think was an updated it will just pause and never finish during prints. I have taken the same file and gcode does not fully print but the s3g file on being copied to the SD will.
I have rebuilt OctoPrint from scratch and it fixed nothing. First with no updates then with updates.
Here is my print of the same design saved at the same time. No changes. The x3g file printed the fan covers great the cgode I normally send to OctpoPi pauses part way through the raft and just stops. Will not unpause with the lcd menu or on OctoPrint.
Just to make sure nothing was messed up I did another two color frog and it would not even start with the gcode yet the x3g file printed fine.
I did not change any S3D settings either. I am at a loss.
As you can see the failed one with the blob at the corner.
[IMG] [/IMG]Editor in Chief
Bitsonline
