Results 3,371 to 3,380 of 4110
09-27-2016, 08:44 PM #3371
- Jun 2016
- Oklahoma
- 904
Is anyone using Hatchbox ABS? I got some in and running it at the similar settings to what I use for Makergeeks ABS and it looks to be over extruding. My test cube is bulging on the top. I am going to run another one reducing the extrusion multiplier from 1 to .95 and see how it goes.
Another question - I am hearing some people talk about dropping back to using the profile for the replicator 1 dual on the QIDI and Flashforge creator pro that they are getting better results. Any thoughts on this?
09-27-2016, 08:46 PM #3372
- Jun 2016
- Oklahoma
- 904
Ok, so one more question. Sort of hypothetical -
This is a simple question which is if I were to set the filament diameter to 1.73 for a 1.75 filament would this potentially cause a slight over extrusion as opposed setting it to 1.77 for a 1.75 cause a slight under extrusion assuming the filament is actually 1.75? This is just a hypothetical.
09-27-2016, 09:23 PM #3373
- Sep 2016
- 80
I have PLA nailed, but I have yet to do anything other than produce a tip-hugging blob when using ABS.
230 on extrusion, 110 on the bed. I am using painter's tape so that I can actually get my PLA stuff off the bed (it was HARD to get stuff off without it).
However, PLA simply will not adhere. Period. I've leveled the bed when the bed was at 110. Same leveling process I use with PLA.
There a trick I'm missing?
NOTE: I've had some luck with a gluestick, but the stuff I'm getting looks like craaaaaaaaaap. Like, missing lines all over the place on my first layer and such.Last edited by Merijeek; 09-27-2016 at 10:20 PM.
09-27-2016, 10:50 PM #3374
09-27-2016, 10:51 PM #3375
09-27-2016, 10:53 PM #3376
I slow down the extrusion rate on the Hatchbox ABS as it. I print it at 220c 110c bed temp.
I didn't change any profiles.
I've been using S3D for a couple weeks now and it allows better control.
My Soultech ABS I run 230c and 110c temps at 1.72 for filament dimensions.
Editor in Chief
Bitsonline
09-27-2016, 11:00 PM #3377Editor in Chief
Bitsonline
09-28-2016, 06:18 AM #3378
- May 2016
- 55
Sounds like you may have the side fan on. That messed my ABS up big time.
Try rubbing your painter's tape down with alcohol. It sticks way too well for PLA, but for ABS, it might be just right. Don't use to much, though, or the tape will wrinkle. Just a little bit on a paper towel.
09-28-2016, 06:21 AM #3379
- Jun 2016
- Oklahoma
- 904
09-28-2016, 06:26 AM #3380
- Jun 2016
- Oklahoma
- 904
Thanks and yea I understand on the extrusion multiplier! This was more a hypothetical to see if I was understanding what could be a result of the value used for diameter.
For instance my new roll is measuring 1.73 - 1.74 so I am thinking that if I go 1.73 and see a bit of over extrusion then 1.74 may be better (maybe .01 isn't enough to make a difference). Would that be a safe assumption?
Again not trying to tune with diameter but just to understand how the setting can affect things.
