Results 11 to 17 of 17
09-19-2016, 11:27 AM #11
yep change all three to 6 - that will give you perimeters made of 2.4 mm of solid plastic and top and bottoms of 1.8mm.
so perimeters and top and bottom layers.
resolution needs to be 'low (faster)'
Combine infill should be every layer - if it will let you.
Otherwise it offsets every other layer - which looks pretty, but is nowhere near as strong.
Have to download a copy of that software and have a play with it.
I've just bought an electroplating with copper kit to make some of my prints super strong. But I've used pla for some pretty tough items.
09-19-2016, 11:52 AM #12
- Aug 2016
- 59
thanks again for your help! much appreciated!
09-19-2016, 04:00 PM #13
- Oakland, CA
- 935
Get a piece of steel. Drill a couple of holes in it, and bend it into a hook shape. Install it in your garage and hang your bike on it - end of story.
Or keep experimenting with home-printed plastic hooks, but don't count on missing your car each time...
09-19-2016, 04:15 PM #14
09-19-2016, 10:20 PM #15
- Aug 2016
- 59
09-20-2016, 03:29 PM #16
Well, let us know how they hold up!
Is that the same hook as the one you referenced?
For the record, what settings did you go with?
09-20-2016, 09:53 PM #17
- Aug 2016
- 59
