Results 311 to 320 of 396
09-14-2016, 06:36 PM #311
- Jul 2014
- 305
I may be stupid but what's the difference between the R7 and the latest fork? Or are they the same?
09-14-2016, 07:23 PM #312
There have been a family of 'Release Candidates'. We are trying to do a 'Stable Release'. RC-7 is the latest version. It is much improved over the original RC-1. I think we will have one more in the family, namely: RC-8. I think that will be the last and final Release Candidate. And that will become an official Stable Release.
RC-7 is frozen in time. RCBugFix is everything we have changed since RC-7 started. You should be working with RCBugFix if you do any work or are bringing up a printer. But the point is... If you get Configuration.h files that work with RCBugFix (or RC-7) it won't be hard to package them up and make them available for the Stable Release when that happens.
09-14-2016, 09:24 PM #313
- Jul 2014
- Eastern Colorado
- 536
Ok, here is my Configuration.h file, and pins_RAMPS.h file.
MakerFarm i3v 8"
RAMPS 1.4
Marlin RCBugfix from August 26, 2016 (#4704?)
Toranado extruder http://www.thingiverse.com/thing:1246951
E3D 1.75 hotend with PT100 sensor http://www.makerfarm.com/index.php/h...grade-kit.html
Capacitive proximity sensor Z endstop/ABL probe https://www.amazon.com/dp/B00542U3M4/
pins_RAMPS.h
Configuration.hLast edited by AbuMaia; 09-16-2016 at 10:18 AM.
09-15-2016, 10:49 AM #314
- Feb 2015
- 371
Where is the RC-7 download located? I thought I might take a look at it.
09-15-2016, 11:26 AM #315
- Feb 2015
- 371
Also, I know people use a text comparison program to look at the differences between two texts. What is a good free one to use to compare these two files?
09-15-2016, 11:34 AM #316
It is here: https://github.com/MarlinFirmware/Marlin/tree/RCBugFix You should be using RCBugFix and not the frozen RC-7. RCBugFix is RC-7 with all known bugs fixed.
I like ExamDiff Pro. But NotePad++ will do a good job of comparing your Configuration.h files.
09-15-2016, 12:43 PM #317
- Feb 2015
- 371
Wow, looking at the RC7 the comparison might not even work. There are a lot of differences on my initial investigation.
I am running ABL, and that section looks a lot different.
09-15-2016, 01:09 PM #318
- Jul 2016
- Pennsylvania, USA
- 255
09-15-2016, 01:20 PM #319
- Jul 2014
- Eastern Colorado
- 536
09-15-2016, 04:47 PM #320
New member with print issue
