Results 301 to 310 of 396
09-13-2016, 11:49 AM #301
You're welcome.
I run all of my printers with used HP DPS-600PB server power supplies. I power a Raspberry Pi, the RAMPS board (VCC) and the RAMPS servo bus (+5V) direct from the 5VSB on the power supply, with three separate wires back to the source. This way, the electronics are always on. I switch the power supply on and off using the PS_ON line from the RAMPS power header, so the 12V bus for the motors and heaters is only on when needed.
I'm running an industrial silicone heater pad under borosilicate glass on my 12", and it delivers a lot of power. I have to use borosilicate because ordinary glass explodes during the fast warmup cycle.
09-13-2016, 08:51 PM #302
- Feb 2015
- 371
09-13-2016, 08:59 PM #303
- Jul 2014
- Eastern Colorado
- 536
I'm running RC7. So far I have only modified the Configuration.h and pins_RAMPS.h files. Where shall I put them? I had to modify the pins_RAMPS.h file in order to use E3D's new cartridge upgrade and PT100 sensor.
09-13-2016, 09:14 PM #304
I'm very interested in having something like this. I have a fork of the beckdac fork with customized branches for my double extruder on various MakerFarm printers. I'd really like to get out of that business, but I've been waiting for Marlin to be ready. I'm personally running RC4 and very happy with it.
If there are going to be MakerFarm samples, do you think it would be appropriate to have Itty Bitty Double Extruder variants, or is that something I need to keep separate?
09-13-2016, 09:38 PM #305
I'm game. Of course that is easy for me to say since the current version isn't currently doing what I want. This is a hobby for me, so I will work on it this weekend. RC-7 here I come.
09-14-2016, 08:47 AM #306
AbuMara: Can you post them here? How about we start a whole new thread for this purpose? Maybe call it something like Marlin RC-7 on MakerFarm ?
SystemSlave: Can you please try to start with AbuMara's files. That way we get some confirmation and Q/A time. And we will have a starting point with the files that handle's at least two people's needs.
09-14-2016, 10:14 AM #307
09-14-2016, 11:51 AM #308
There was a short "how should we go about this" discussion some time ago that led to no clear scheme, and the problem is worse now than ever. All need to remember that the MakerFarm product line is far more complex than it used to be. Long gone are the days where a single set of files works for everyone with a MakerFarm printer, at least not without some adjustments.
Don't get me wrong - I'm all about sharing lessons learned and helping out the next user. As a minimum, things like thread posts, comments, descriptions, filenames, and foldernames should probably clarify what the content applies to. Even without factoring user modifications, the type of electronics (RAMPS, RUMBA, RAMBO), type of LCD (character vs graphic), type of extruder (Greg's Wade, bulldog, Pegasus, Titan single vs dual), and bed compensation scheme are examples of ways MakerFarm printers can differ as far as a firmware build and configuration parameters. Many users can readily deal with tailoring standard files for their unique configuration, but history has shown that some, especially new users still somewhat unfamiliar with the firmware and lacking confidence in what they are doing, will struggle in doing this. If that is considered somehow from the beginning, maybe it'll be easier for all in the long-run.Last edited by printbus; 09-14-2016 at 12:51 PM.
09-14-2016, 01:32 PM #309
- Feb 2015
- 371
I picture myself the person you are talking about here! I know there is a new firmware out but have not adopted due to the reasons you mention. First, I am not 100% sure what needs to be done to make the RC-7 work on my machine.
Perhaps a checklist of things that need to be changed in the RC-7 to fit your machine could be made? That would perhaps give the user the confidence to at least try it out.
With that in mind, what changes need to be made?
*change esteps to fit your chassis, X,Y,Z,E
*Activate ABL if using
-define pins in pins.h is using ABS
-Set probe extend retract degrees
-set probe points
-define offsets
*define motherboard
*Define temp probe
*adjust PIDs
What else would a user need to change in RC-7 to fit their machine? Also, where can one find the current stable RC-7 file for use? Link?
09-14-2016, 04:46 PM #310
Ender 3v2 poor printing quality
10-28-2024, 09:08 AM in Tips, Tricks and Tech Help
