Results 41 to 50 of 96
Thread: Anyone used Printbite surface ?
09-10-2016, 03:16 PM #41
I will check back in a few mins then. The rep from there said they were out of most of them and for some reason several showed up as in stock. I was thinking going larger like you suggest to get an extra. I will ping them first and ask.
I almost pulled the trigger on the Borosilicate glass last night but I dont want the size that is a bit too small or the size that is just over-sized so I am trying to source one that is the correct size for the QIDI printer.
Editor in Chief
Bitsonline
09-10-2016, 04:44 PM #42
- May 2016
- Annapolis, MD
- 523
This one is not by cncartist, but is an exceptionally useful hinge for the QiDi's front door. http://www.thingiverse.com/thing:1697406 If you slide it to the right it locks the door up in the open position, rotate down by 30 degrees and you can lift to remove the entire door. Kind of made the door clip unnecessary though.
09-10-2016, 11:21 PM #43
09-11-2016, 04:42 AM #44
- Jan 2016
- 326
Can I use glue sticks on Printbite?
09-11-2016, 05:18 AM #45
yes - but why ?
anything that sticks to gluestick will naturally stick to printbite.
The thing about printbite is that when it is hot most filaments will stick really well to it, when it cools down parts become loose.
If - like me - you are impatient then wait a few minutes and hit the part with a plastic hammer and it knocks it loose.
The other thing about printbite is that it is an extremely tough and hard surface that is perfectly smooth. Giving the base of the printer item a really smooth shiny finish.
Using gluestick on it will not only ruin the finish, but actually reduce it's usefullness by stopping the release of models when it's cooled down and also reducing the grip when it's hot.
Check my thread for things you don't use with printbite - so far just got a few. If you use a flexible rubber fliament you might - conceivably - use a very light layer of pva to stop it sticking too much to the printbite, but you'd be better off just switching to flexible pla - which works fine without pva.
The only thing I would absolutely not use on printbite is Mymat nylon. It end up with an almost permament weld. That said it works great on pva and is the only nylon filamet I've tried that does not warp and will print really well without a heated print volume.
It's just not compatitble with printbite.
09-11-2016, 11:29 AM #46
- Jan 2016
- 326
I thought that ESUN PETG doesn't stick well to Printbite. The first layer and especially supports don't stick well to Printbite. I set the heated bed temperature to 85 degrees. the parts come off Printbite very easily without using any force. I think that the bed leveling may be off.
09-11-2016, 03:16 PM #47
ESUN PETG sticks perfectly on clean glass that's at 80c. I've never needed anything else special to get it to stick.
09-11-2016, 03:37 PM #48
Esun Petg sticks great at 60c.
In fact I only use 60c for everything.
you do need a tighter calibration with the Petg than with pla
but other than that it works brilliantly. The esun Petg in particularly sticks really well and doesn't seem to warp at all
09-11-2016, 07:38 PM #49
- Jan 2016
- 326
How should I clean the Printbite surface? I leveled the bed a few times and it appeared to work better. Curious Aardvark, what machine and slicer do you have?
09-11-2016, 08:18 PM #50Editor in Chief
Bitsonline
New member with print issue
