Results 1 to 10 of 19
Thread: Support material for Ninjaflex
08-18-2016, 05:27 AM #1
So my Ninjaflex prints are coming out fantastically. So much so that I am considering making this my go to material. However for this to work I need a decent, soluble support material. PVA? Any recommendations?
08-18-2016, 05:44 AM #2
try pva, or the new polymaker support material
http://shop.3dfilaprint.com/polysupport-248-c.asp
But what was your mod that made ninjaflex work ???????????????
This is about the 5th time of asking :-)Last edited by curious aardvark; 08-18-2016 at 05:52 AM.
08-18-2016, 07:11 AM #3
Dude, ninjaflex works fine. What's the problem?
08-18-2016, 08:03 AM #4
only green ninjaflex works on an unmodified creator :-)
actually at the moment I'm using flexismart on the knp - which does have modified extruders (well better ones anyway), which is very good stuff and polyflex on the creator.
But I do have a bunch of red ninjaflex and filaflex that just won't feed on either machine.
08-18-2016, 08:44 AM #5
For now I simply opened up the 'output' hole on the extruder and inserted a teflon tube which had one end end cut to the shape of the extruder gear. Once I get a gap I will remake the entire extruder gear plate out of aluminium with the necessary modification in the gear zone.
08-18-2016, 08:45 AM #6
08-18-2016, 08:51 AM #7
08-18-2016, 10:07 AM #8
I get it, yeah that's a good idea ! Got some spare teflon tubes around I can play with. Cheers :-)
And NO ninjaflex will not work as support for itself - that stuff sticks like glue to itself. You'd never be able to remobe supports.
08-18-2016, 03:00 PM #9
That Polymaker video was very very interesting. Methinks I shall be purchasing some as soon as the pressure is off. That looks like truly amazing filament!
08-19-2016, 12:33 AM #10
