Results 1 to 10 of 73
Thread: Diy it?
07-04-2016, 01:33 PM #28
- Sep 2013
- 308
Acrylic works and its is what we original planed to make printers with.. abs is better because acrylic often breaks on the fine snap fit tabs, but it still works
and a bit of hot glue can solve any problems you have with it. I think that 1/8 inch birch plywood would also work and so would petg. petg would be the strongest.
We have been doing the parts in 3mm thick plastic but because we designed in openScad it should be relatively easy to cut parts from other thicknesses
try playing with the SheetThickness variable in the openSCad files.
Sorry Im not in here answering more questions right now.. Im in the middle of moving, so I spending lots of time boxing and cleaning, loading trucks etc.
