Results 1 to 10 of 73
Thread: Diy it?
06-07-2016, 12:53 AM #26
- Mar 2016
- 68
Viscosity and flowrate remain a problem in your scenario, the idea behind the thick layer of resin is to provide a bit of a buffer so that the resin can fill the gaps quick enough! With a layer of less than 1mm the surface tension would be a problem and might even lead to pearls of resin floating on top of the water due to hydrophobic behavior!...
New member with print issue
