Results 1 to 10 of 11
04-04-2016, 03:16 PM #8
You can make one using a 12v power supply and some Nickel-Chrome wire but you don't have any control over temperature unless you also use something like a servo tester or your voltage can be controlled on your 12v power supply.
However, for what you need I think a hot air gun would work
New member with print issue
