Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Anyone tried to make a heated bed?
    I accidentally bought some ABS and am printing very small items for miniature scenes. I might want to keep it as it should be stronger for certain prints (fragile legs) but I did have a problem with warpage even on a small item. Just wondering if there is a fairly simple way of heating the bed to avoid this problem. Otherwise I will have to exchange it for PLA which is a lot harder to clean up.
    Senior Engineer
    Jun 2014
    Burnley, UK
    If it is just a temporary thing then just use a hot air gun to keep the print warm while it is happening.
    Carefully.
    What temp is good - I could use a thermometer. I just got this HUGE roll of brown ABS and if I can finally set a good temperature for it it should work well. I may need to do lots of prints (mostly miniature furniture so small base) so likely I will need something more permanent.
    Student
    Feb 2016
    Austin, TX
    Follow Elysian On Twitter
    I was looking into making a heated bed for the M3D, but ultimately decided it's not worth it. IMO it's a good starter printer, to figure out 3D printing, but given the chance to upgrade to a better printer, I took it.
    Student
    Mar 2016
    Fresno, CA
    Not trying to be funny, but... what temperature would be needed? Perhaps one could feed the 3D ink externally and put a simple heat source in the hole where the internal spool would have resided.
    Few people have created diy heated beds for the M3D Micro using usb mug warmers. If you have access to the M3D support forum there are some recent discussions going on about diy heated bed mods/hacks.
    Student
    Mar 2016
    Australia
    Follow tegregg On Twitter
    Heated Bed
    Quote Originally Posted by chaotic1 View Post
    There was a kickstarter for a heated bed which isnt too far away from being delivered. You are able to pre-order from that page.
    https://www.kickstarter.com/projects...ated-print-bed
  8. #8
    Technologist 3dex ltd's Avatar
    Dec 2015
    United Kingdom
    Follow 3dex ltd On Twitter Add 3dex ltd on Facebook
    You can make one using a 12v power supply and some Nickel-Chrome wire but you don't have any control over temperature unless you also use something like a servo tester or your voltage can be controlled on your 12v power supply.
    However, for what you need I think a hot air gun would work
  9. #9
    so that's like another $135 with the enclosure and heatbed.
    And if I had a micro - I'd definitely get the hot bed.
    printer costs $349 - total cost to make it properly useful: $484
    For a printer with a really small print volume.
    Yeah it's cute, but for what it is - in the current market, still over priced.
  10. #10
Tags for this Thread
