Results 801 to 810 of 4110
04-01-2016, 07:47 PM #801
If you are running Sailfish on your Qidi Tech you should be using this version of RepG
replicatorg-0040r33-Sailfish
Found here https://www.thingiverse.com/thing:32084/#files
04-01-2016, 10:48 PM #802
- Mar 2016
- 10
Anyone know anything about the upgraded 2016 version of this printer? Getting ready to pull the trigger on it from ebay. This will be my first printer.
04-02-2016, 10:47 AM #803
- Mar 2016
- 14
hi guys,
im a new user of this qidi tech,
ive got mine yesterday and print some 3Dbenchy, the elephant and some random stuff
for now i am very2 happy with this printer
next , i'm trying to print bigger object which took 8 hour
but , the print stop extrude at my 50% job
the machine is working but no extrusion happen at my right extruder , it is seem to clogged/block
i try to unload and load the filament but still there is no extrusion happen.
i use PLA 230C extruder - 40c heatbed
can someone help me to overcome this problem ? thanks
04-02-2016, 02:49 PM #804
- Feb 2016
- 360
Having a huge issue with curling today and last night. Everything I print in PLA or ABS has a corner or edge that curls up. Have tried adjusting heats a bit, cleaned a reprepared glass a couple times. I can not for the life of me tell whats causing this.
04-02-2016, 08:45 PM #805
04-02-2016, 09:29 PM #806
- Mar 2016
- 52
04-02-2016, 09:31 PM #807
- Mar 2016
- 52
I am hearing some audible creaking from my y axis, on the left side of the machine. It could also be the extruder slipping.. Maybe 220c is too low for my black abs, and the extruder cant push the filament through... Then again i have no indication of under extrusion. Must be noise in the bearings or carriages. Anyone else notice that?
04-02-2016, 10:35 PM #808
- Mar 2016
- 45
Hi Guys,
So I order the Maghold Build Platform and the Glass from McMaster and the PET Tape from Amazon. However the Aquanet spray cannot be shipped to me in Asia as they not ship outside US. Any idea what chemical to look out for the hairspray or any hairspray will do?
Thanks.
04-03-2016, 01:07 AM #809
- Mar 2016
- 14
04-03-2016, 08:46 AM #810
Heat your extruder up and then remove the nozzle with a 9mm wrench.
Hold the extruder hot block with pliers when doing this. Be Careful it's hot.
Pull the nozzle off and then the PTFE tube.
Turn the printer off
Clean out the PTFE tube and or the nozzle. I use a heated small drill bit and the finest piano string.
Put it back together cold. Heat the printer backup and while holding the Hot block tighten the nozzle.
This is just just a quick how to description there are several Youtube videos that cover this just search Flashforge, CTC or Makerbot Dual extruder clogs.
