Results 1 to 10 of 476
Thread: Itty Bitty Double Extruder
03-31-2016, 09:31 AM #1
3mm and 1.75 in the same IB double
Clough42 - I also have interest in 1.75 mainly for availability issues rather than function. However I have an inventory of 3mm and would like to cover both. Any chance of getting an STL of an extruder block with 3mm on the right and 1.75 on the left? Or is there a liner tube out there that goes from 3mm to 1.75? if not, there should be.
/quick search shows 2mm ID 3mm OD pfte is available. Maybe a good way to go, possibly even reversable once installed.
I am a Happy IBD user although I'm kind of over dual material printing since the self support in Simplify 3d is so dang good - Thanks again.
03-31-2016, 10:48 AM #2
TJC - see if you have any somewhat used BIC pens laying around. The ink tube is pretty close to 3mm OD, 2mm ID. Some people have used lengths of spent ink tubes as a liner in the 3mm-native Greg's Wade extruder body provided by MakerFarm. I've seem some pens with tubes that are too narrow - especially giveaway-type pens that are likely trying to go cheap on the amount of ink.
