Results 1 to 10 of 10
Thread: RADDS Info Thread
12-26-2015, 07:56 PM #1
- Aug 2015
- Vail, CO, USA
- 36
RADDS Info Thread
I'm anticipating problems with the new RADDS board I got to replace my fried RAMPS board, so I've created this thread so that people can ask and answer questions about the board. A list of helpful web pages is below, I'll update them occasionally. Documentation on this board is limited to a description of its features so this might be the only place to get help.
Makerfarm RADDS Page
Official RADDS Page
Repetier Firmware
A few snags I hit:
- The RADDS board does not come with the required Arduino Due. Get one!
- Marlin firmware does not work with the RADDS. You must download Repetier firmware from the link above.
- Configuration is similar to Marlin but not the same. Use your stock Marlin configuration to guide you.
- You may have to download IDE profiles for the Due before you can upload firmware. Go to Tools > Boards > Manage Boards and install the SAM board profile. Restart the IDE, and you should now be able to select the Due as your board.
This post will be edited occasionally to include new info I find.
12-27-2015, 09:17 AM #2
- Aug 2015
- Vail, CO, USA
- 36
The first problem I hit is related to z homing. The X and Y axes home fine, but when I press the "Home Z" button in Cura, the Z motors only make a high-pitched squealing sound. I think this problem is firmware-related so I will look around in the Repetier firmware for a little longer.
12-27-2015, 10:25 AM #3
12-27-2015, 10:41 AM #4
- Aug 2015
- Vail, CO, USA
- 36
Z homing feedrate is actually lower than my Marlin setting, I don't think that's the problem. However, the Z axis does move normally when not homing so perhaps another homing related setting is off?
12-27-2015, 01:31 PM #5A few snags I hit:
I promise you won't have any problem getting the changes merged into the code base if you get them working!!!
12-27-2015, 02:48 PM #6
- Aug 2015
- Vail, CO, USA
- 36
So port the Marlin code to the new board...
By "port" do you mean modifying Marlin to work with the Due/RADDS?
12-27-2015, 03:12 PM #7
Yes: https://en.wikipedia.org/wiki/Porting
Ultimately... It is almost a given that Marlin is going to run on the Due micro-processor. But we have some clean up work to do first.
12-27-2015, 04:08 PM #8
- Aug 2015
- Vail, CO, USA
- 36
OK. Not sure what "clean up work" entails, but if it's successful please let me know!
05-10-2016, 05:44 PM #9
- May 2016
I agree to the problems - I replaced my RAMPS board with an Arduino Due RADDS combo. steps so far
Loaded driver for board shows on com 6.
Added Due board to Arduino
Ran Repetier online config tool and uploaded to board with Arduino (ran as administrator) per instructions - had to do this several times and changed EEPROM from 1 to 2 etc each time.
Had uploads show as completed and LCD lit up but did not show any message.
After several tries was able to get the printer name etc on LCD and can switch thru menu but nothing will run from LCD. Repetier Host says its connected to printer on com6 but does not report any information and does not communicate with printer G Codes or otherwise.
I am just learning so I would guess i missed something but not sure what... Help greatly appreciated.
05-11-2016, 09:26 AM #10
So more thinking about 32-Bit boards. RADDS is one of the platforms detailed in the discussion:
https://github.com/MarlinFirmware/MarlinDev/issues/398
Today, 02:07 PM in General 3D Printing Discussion
