Results 1 to 10 of 22
11-21-2015, 06:29 PM #1
- Feb 2015
- 371
Adding M600 to change filament to Gcode
I have been trying to modify some code for my prints by adding a M600 command to change filament. I got it to work once by just putting the filament in the actual code. I have been trying on another print but cannot get it to work! I just sits in one spot and extrudes a huge mess of filament.
Here is a section of the code. I added the M600 right before the printer starts the fill section of the top layer. I want this to be a different color.
Code:G1 X189.521 Y94.348 E1544.45744G1 X190.463 Y94.995 E1544.47148 G1 X191.309 Y95.762 E1544.48552 G1 X192.053 Y96.643 E1544.49969 G1 X192.681 Y97.628 E1544.51404 G1 X193.172 Y98.676 E1544.52827 G1 X193.525 Y99.793 E1544.54266 G1 X193.732 Y100.944 E1544.55704 G1 X193.788 Y102.12 E1544.5715 G1 X193.788 Y197.87 E1545.74823 G1 X193.732 Y199.056 E1545.76282 G1 X193.525 Y200.206 E1545.77718 G1 X193.172 Y201.323 E1545.79158 G1 X192.681 Y202.372 E1545.80581 G1 X192.053 Y203.356 E1545.82016 G1 X191.309 Y204.237 E1545.83433 G1 X190.463 Y205.004 E1545.84836 G1 X189.521 Y205.651 E1545.86241 G1 X188.498 Y206.164 E1545.87647 G1 X187.431 Y206.527 E1545.89032 G1 X186.325 Y206.741 E1545.90417 G1 X185.181 Y206.8 E1545.91825 G1 X114.819 Y206.8 E1546.78296 G0 F10500 X114.745 Y205.82 M600 ; TYPE:FILL G1 F3600 X107.138 Y198.214 E1546.91517 G0 F10500 X107.221 Y197.731 G1 F3600 X106.762 Y197.272 E1546.92314 G0 F10500 X107.121 Y197.065 G1 F3600 X115.881 Y205.825 E1547.07539 G0 F10500 X115.739 Y206.248 G1 F3600 X115.215 Y205.725 E1547.08449 G0 F10500 X115.315 Y205.825 G1 F3600 X107.121 Y197.63 E1547.22691 G0 F10500 X107.121 Y196.499 G1 F3600 X116.447 Y205.825 E1547.389 G0 F10500 X117.012 Y205.825 G1 F3600 X107.121 Y195.933 E1547.56091 G0 F10500 X107.121 Y195.367 G1 F3600 X117.578 Y205.825 E1547.74267 G0 F10500 X118.144 Y205.825 G1 F3600 X107.121 Y194.802 E1547.93425 G0 F10500 X107.121 Y194.236 G1 F3600 X118.709 Y205.825 E1548.13566 G0 F10500 X119.275 Y205.825 G1 F3600 X107.121 Y193.67 E1548.3469 G0 F10500 X107.121 Y193.105 G1 F3600 X119.841 Y205.825 E1548.56798 G0 F10500 X120.406 Y205.825
11-21-2015, 08:15 PM #2
Should "TYPE:FILL" be in parentheses? I've never seen a text command in G-code programs, only action descriptons or tool geometry within parentheses.
11-21-2015, 08:40 PM #3
- Feb 2015
- 371
That is what my slicer puts in. I kinda like it. It makes inserting these M600 commands a lot easier...in theory.
11-21-2015, 09:23 PM #4
So TYPE:FILL can replace the several lines of code required to execute this procedure. It's my understanding that M600 pauses machine, but what about the other M600 codes? Extruder on, extruder off, or change filament? The program has your tool paused and all other commands are on, I think the reason you are getting a pool of plastic. Extruder is still on M604
11-21-2015, 10:14 PM #5
- Feb 2015
- 371
The Type:FILL is just something my slicer puts in. There are no actual commands issued in that line. The ";" tells the printer to ignore what come after in that line. At least that is how I learned it. I could be wrong.
The M600 command causes the machine to move to the home position and retract the filament, then pause while you load new filament and push the button. I had thought it was supposed to lock the x and y axis motors but I can still move them. It is tricky and I wish there was a way to have it work better. What is a M604 command?
11-21-2015, 11:43 PM #6
Sorry, I'm new to 3d programming. I can track your cartesian coordinates, but then you call for a filament pause. I don't know what's included in that command but it looks as if something is missing.
- M600 - Park head to allow filament change or pause of print
- M601 - Unpark head to resume printing
- M602 - Turn on/off current extruder motor (e.g., for cleaning)
- M603 - Display LCD alert, sound beeper and wait for button press.
I'd think a M601 would be necessary to resume after pause. But you've said that your process has worked in the past???
11-22-2015, 08:26 AM #7
M600 has a number of parameters. When ever I use it, I do something like M600 Z50 to raise the nozzle up above the part. That is important for two reasons. First, it gets the hot end away from the print. But the other reason that is important is you need room to work. Once I get the filament changed, I need to manually turn the gears to fill the nozzle with the new color. So I put a piece of paper on top of the print and let the nozzle extrude hot filament until the color changes. The paper keeps the new filament from sticking.
11-22-2015, 09:01 PM #8
- Feb 2015
- 371
The first M600 works great. All I add is the m600. The printer retracts, raises up off the bed and then moves over to the edge of the printer and retracts some more to move the filament out of the nozzle. I then manually add new filament and hit the button. It moves back to where it left off and resumes. I don't add any more to it then that.
On on the second m600 it just spits out filament. The first works, just not the second!
11-22-2015, 11:40 PM #9
Thanks for the tips!
I'm not at that level yet, but this knowledge will come in handy. I'm just trying to get a feel for the variable needs each program/shape demands. I created some standard size blocks and circles/rings files for calibration and trial and error test runs. It's amazing how differently a 12.70cm cube prints when you start changing the variables from print to print. I'm using Simplify for slicing, and am intrigued by the options you are given to dial in a print/build.
11-23-2015, 10:27 AM #10
