Results 21 to 25 of 25
Thread: Marlin 1.1
09-26-2015, 03:49 PM #21
Are there two pegs that come up higher than everything else? Or is that closest mound of plastic a result of the nozzle driving into the part? If there are supposed to be two pegs of plastic, it looks like that close one is getting too hot. You can add a cylinder that goes up a little higher than the extruder part just to burn some time between layers. That will let that peg cool down and come out better. Maybe a cylinder that is 1" in diameter would do the trick.
09-28-2015, 08:55 PM #22
- Dec 2014
- Canada
- 498
yep there were suppose to be two mounds.. the nozzle and heating element went down. it printed fine. just my gcode error in the ending script
10-18-2015, 07:12 AM #23
- Dec 2014
- Canada
- 498
Is marlin 1.1 available for Due with Radds?
10-18-2015, 03:47 PM #24
What is a Due with Radds ? Marlin should run on pretty much any Arduino board setup for 3D Printers.
10-19-2015, 07:04 AM #25
- Dec 2014
- Canada
- 498
