Results 41 to 50 of 51
Thread: 12" Alum Y Plate
04-06-2015, 06:52 AM #41
- Dec 2014
- Canada
- 498
How much does the stock wood plate weigh? maybe we can trim the fat enough to at least match the weight.
I didnt show it in my sketch but i think it would be great to add some support for the heated bed wires. to reduce flex/wire movement.
Please post the design you want to cut on here for more input, before you cut. if you dont mind
04-06-2015, 09:33 AM #42
- Nov 2014
- Brevard, NC
- 182
The wooden build plate I think should be just a little less than 18oz for the 12" plate & little over 12oz for the 10" build plate. Without taking my 10" bed apart, I took the weight of the wooden spool piece which came out to a weight of .51oz. I created a .stl file of this part & it came out to 18.2 cubic Cm. Using those 2 measurements, and a dxf file of the 12" & 10" plate, I came up with those weights. Feel free to correct me, if I am way off.
04-06-2015, 09:45 AM #43
How is the open plate going to affect heat bed cooling and control?
04-06-2015, 10:18 AM #44
- Mar 2015
- Palo Alto
- 63
Seeing as to how most people have insulation between the heatbed and plate which should prevent drafts (convection & underside radiation) and the heat has to travel through the 4 steel screws to get to the aluminum (conduction), probably not much. If you don't have insulation, it might make a great excuse to add some since you'd have the bed apart anyway and you'd get faster and more even heating.
04-07-2015, 06:16 AM #45
- Feb 2015
I would be interested in one of the lightened ones.
04-10-2015, 07:22 AM #46
- Dec 2014
- Canada
- 498
So any update?
04-16-2015, 08:24 PM #47
- Nov 2014
- 138
How is this coming.
05-06-2015, 09:22 PM #48
- Dec 2014
- 28
tech master joe2.jpg Some of us still remember.
05-06-2015, 09:38 PM #49
05-07-2015, 08:41 PM #50
