Results 21 to 30 of 51
Thread: 12" Alum Y Plate
04-02-2015, 07:46 AM #21
- Feb 2015
- Miami
- 12
04-02-2015, 11:01 AM #22
- Feb 2015
- Flagstaff, AZ
- 73
I don't see the hole for the screw that triggers the contact switch or the hole for bolting the plywood in the middle into those 4 slots.
04-02-2015, 11:37 AM #23
- Dec 2014
- 28
04-02-2015, 01:25 PM #24
- Nov 2014
- 138
04-02-2015, 04:21 PM #25
- Nov 2014
- 522
TMJ I pm'd you. Take your pick as to which you cut I don't know the difference between them honestly...
04-03-2015, 02:28 AM #26
- Dec 2014
- 21
Hi TechMasterJoe
Would u deliver to Switzerland?
04-03-2015, 08:05 AM #27
- Mar 2015
- 32
tmj what is the weight on the 6061
04-05-2015, 04:21 AM #28
- Nov 2014
- Orange, CA
- 78
here is some screen shots on weight apx 950 grams
i cut 23 out of 7075 T6 and the holes for the bed are are 2.52mm measured and can be tapped to 3mm or drilled
i will setup stuff to sell 12 of them this week the rest I'm going to be sending to Colin for other reasons ;-)
i have changed my mind about 6061 T6 it's to easy to bend 7075 is 6 times harder for next to no extra weight (10~20 grams or so)
you can stand on them zero flex
even with the holes
the plates are .200in apx 5mm thick
i will post pics and contact info soon
they will include the parts that i cut out something for you all to play with
the slots are 28mm wide the part i cut out are 2.0~2.4mm smaller (waterjet)
04-05-2015, 06:50 AM #29
04-05-2015, 06:55 AM #30
- Dec 2014
- Canada
- 498
Dibs on one of them
Do bed magnets deteriorate.
