Results 331 to 340 of 476
Thread: Itty Bitty Double Extruder
02-07-2015, 07:14 PM #331
- Nov 2014
- 138
Thanks! Sniffle.
02-08-2015, 10:12 PM #332
- Dec 2014
- 16
I am running a 1.75mm and a 3mm on the same IBDE. Using slic3r and setting filament size for each prints fine. There is only one estep but it is the same value for both, correction is done by changing the filament size and leaving the estep alone. The hardest part for me is my 1.75 and 3 mm nozzles are not the same length. So getting it level is a pain.
02-09-2015, 09:15 AM #333
Mwyrick is running a prototype of a mixed block with both filament sizes. This should work as long as you're not using volumetric extrusion. If you're using linear extrusion (the default) Marlin doesn't know the diameter of the filament. Your slicer just needs to know the filament diameters.
If there's interest, I can make the mixed blocks available.
02-14-2015, 07:15 PM #334
I just wanted to report back. I'm having good results with Ninjaflex with the Itty Bitty. It's recommended that you don't print it faster than 20mm/s and I'm using 15mm/s. The parts are pretty small, around 1" and look pretty nice.
Bambu P1S/AMS
02-14-2015, 08:25 PM #335
Good info Rob I have a few NinjaFlex parts to print and need to tweek the settings.
02-14-2015, 10:42 PM #336
02-15-2015, 10:11 AM #337
Could you add to the main post all the extra parts and maybe some places on where to source them?
I ordered an extra hexagon from makerfarm. A couple NEMA 14 stepper motors from pololu, as mentioned earlier, but I'm at a loss of where to find a HXT900 servo. Also, what Z probe snap switch do you use as well? It would make it easier for people just getting started to be able to click links to buy stuff. (I'm not even against you putting referral links so you get paid for your work.)Last edited by stridera; 02-16-2015 at 12:05 AM.
02-16-2015, 06:48 PM #338
I've been making some updates to my web site today to make sure all of that is clear and included in the instructions. The complete list of parts with links is here: http://clough42.com/go/itty-bitty-double-extruder/
If I've missed anything, let me know.
02-16-2015, 07:07 PM #339
3mm. Clough's design is for that size.
Bambu P1S/AMS
02-17-2015, 02:02 AM #340
Purchased everything and I'll put it together when everything arrives! Thanks for the help. The update is perfect. I wish I had seen the servo when I ordered the part pack to save you having to ship an extra package. Either way, I can't wait to do the dual prints!
