Originally Posted by
lovincup
Both the Makerfarm wooden and aluminum groove mount are a little too thin to provide adequate contact between the top of the e3dv6 and the recess in the bottom of the accessible extruder. The result is the e3dv6 is loose and not firmly secured to the x carriage. (you can wiggle it with your hand). This was easily overcome by printing an ABS shim (effectively a printed washer) and placing it in the recess in the bottom of the extruder. It gets sandwiched between extruder and the hotend. Perfectly secured now. I have the Direct Drive 3MM e3dv6 and the wooden x carraige.
