Results 41 to 50 of 172
11-08-2014, 08:08 AM #41
We are fighting a similar issue in this thread: http://3dprintboard.com/showthread.p...lling-Glitches
If you scroll to the end, I have some debug code inserted into his Marlin_main.cpp file. I suspect we are going to get his problem figured out pretty quickly. And there is a fair chance his problem is the same as your problem.
Fri, can you post your Configuration.h file? I want to check something.Last edited by Roxy; 11-08-2014 at 08:43 AM.
11-09-2014, 08:30 AM #42
- 114
11-09-2014, 09:56 AM #43
Fri, do any of the end point limit switches get pressed by the bed when you are doing a G29?
11-09-2014, 11:33 AM #44
- 114
No, it does not. Have to say, I don't have any endpoint limit switches.
11-10-2014, 10:25 AM #45
- Jul 2014
- Eastern Colorado
- 536
How do you home X and Y without endstop switches?
11-16-2014, 10:29 AM #46
- 114
11-16-2014, 11:33 AM #47
- Jul 2014
- Eastern Colorado
- 536
Do any of your min switches get hit during a G29?
11-16-2014, 11:57 AM #48
- 114
Yes, Z . I am using a proximity sensor. Z is then also triggered at the last leveling point.
11-16-2014, 12:35 PM #49
- 114
Attachment 3487Attachment 3488Attachment 3489
This is after a factroy reset M502, M500 G28 G29. Then the eeprom after a reconnect/reset.
11-16-2014, 02:31 PM #50
