Results 1 to 10 of 396
10-18-2014, 04:11 PM #11
I am in the process of setting up Auto Bed Level and ran into a few issues.
I used this set of videos to help me through the process...
http://www.youtube.com/watch?v=YpiOsetkIRg
When I went to run the G28 command to home the printer, it now homes near the center of the bed, and not the very back right corner like it used to.
How do i change this back? I am afraid to run the auto level command, cuz I think it will try to go off the bed too far now sense its starting in the middle.
This is probably due to the home position being different in the firmware linked in the first post here.
EDIT
Just went ahead and tried the G29 command to have it run auto level. (still cant figure out how to get home back to 0,0,0)
That seemed to work fine, it took 6 readings and stopped at the last position.
But, if I have the printer start a print, it does not autolevel first.
Is this something that will have to be added to all my gcode?
I see in Cura I can put commands at start and end.
Should I add the G29 command that? Or should I remove the 2 lines that have the G28 command and put G29 there?
I pasted my start code below.
And if I do, I assume it will run autolevel before the print, and store those readings, and proceed to do the print with those readings?
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
EDIT.......................
OOOOOOOOOOOK, well taking out the 2 G28 lines and adding G29 was baaaaaaaad
Extruder moved RIGHT, hard crashing X and tried to go even further, slipping the belt, had to flip the power switch !!
Should the G29 line have anything after it? Or just G29?
EDIT..........................
Well this is odd, now G29 doesnt even work in Pronterface.
Printer does nothing, Proterface reads...
SENDING:G29
echo:Home X/Y before Z
It also says that if I try to home just Z
X and Y will home seperately just fine.
G28 seems to work, though it homes Z in about the middle of the bed.
The printer moves to the X and Y end stops,
then moves to about the middle of the bed, lowers the probe and end stops it, raises the probe, and stays there.
Now if I try to do a print, and have the original G28 commands in the gcode like before I started all this autolevel stuff,
the printer will home X and Y, then just start printing, without homing Z
It starts to print, and it too low, touching the bed.
So, I am basically stuck at this point and cant print till I get something working rightLast edited by jtice; 10-18-2014 at 07:09 PM.
