Results 1 to 10 of 27
09-19-2014, 12:03 AM #10
- Jul 2014
- Munich
- 45
So a few hours together with an additional set of hands and eyes (ok and 2 bottles of wine),
so we readjust the belts and checked the X Motor again ( alone I think never check him again bec checked befor mounting)hr was running much to strong.
So changed motor readjust all belts and all pololus (Voltage around 250-260mV)
Adjust the Printbed and start first print.
Result not bad for the first print Block 20x20mm result 20,1x20,15mm but with a lot of missing steps in Y ( My Mistake Y has 2 motors so need to use a bit more Power)
I also cuttet the cover a bit so I can remove it everytime.
So today finaly adjust Y Pololu and change the firmware
In the Firmware I ´ll change the max width for X looks like here is in the single Extruder Version also the value for the Dual inside so can not use the full 400mm range
So think tosay I can clean the cabeling a bit than will close the Printer.
Next steps are already in Planing I get a few Profiles to Extend the Frame after think will close the sides with plates.
Best regards
Thomas
