Results 1 to 10 of 27
09-03-2014, 02:45 AM #1
- Jul 2014
- Munich
- 45
Frame / Adjustment / Z axle / Printbed
So I finished checking and readjustemnt of the frame yesterday
I checked every adge in every direction readjust if neccessary and checked again all until all point were in the right angel and flat to the other profiles.
(The Block is a grinded part with perfect 90° angles and absolut flat a realy helpful tool)
I also insert the spindel holder and spindels
holders plate and the plate themself
2 Point I need to double check today
One screw I destroy ,
Pulley of the spindle so I need to remove it again to change the screw.
and one of the holders plate (sinter parts) has a too small hole so I need to drill it to right size today , ( I propose to check all holes of the sinter parts before sometimes they are a bit to small)
if this is finished I can fix the plate and start the first fine adjustment of the plate position ( make it even to the frame)
so more hopeflully this evening
so far around 5 hours work include preparation not difficult yet,
but you need to work realy correct (special on the frame) to get all in the right angle a third hand would be good (its possible alone but need more time)Last edited by Luchador; 09-03-2014 at 02:55 AM.
