You simply cannot solder the hot end wires. Soldering will melt again and disconnect. Crimping and then capton would work. The rest should all be soldered.
Usually the case... But I wanted my resistor in my hot end soldered. I have my resistor leads come out 3/4" and bend upwards. That lets things cool off enough the solder will hold and make a good electrical connection.
