05-25-2014, 08:36 AM #3
Agreed... There are way too many variables to think the first time you started a print, it was going to work. And on something like this, I suspect I would have to play with different support material settings until I found one that was compatible with the design, printer, and plastic.
And looking at it from a different perspective... You are dealing with the Open_Source communities when you play with 3D-Printers. If this business really did get going, you would have reverse .STL compilers showing up very quickly that would capture the stream and save it as a normal .STL file. My guess is the reverse .STL compilers would be prevalent within 2 months.
