Results 51 to 60 of 60
Thread: Potential resolution
04-17-2014, 09:17 AM #51
No need to have more output on the card. You just need to use a different frequency (i.e.: 10-15 Khz = Kit 1, 20-25 Khz = Kit 2).
The Peachy Pro have a focused laser, but I dont know what they are using. Rylan seems pretty good at finding cheap stuff
04-17-2014, 01:41 PM #52
- 16
I thought it uses a 405 nm laser. Glass doesn't block much until you get to the shorter wavelengths. 405 would pass completely through. So, a glass lens would work fine, even down to about 325 nm or so.
04-17-2014, 02:27 PM #53
- Dec 2013
- Georgia
- 934
I see glass does better at letting UVb pass through than I would have expected... A 405nm laser? I thought photopolymers needed UVb to cure them, which is a bit below that, and that's just barely at the edge of UVa.
Is the resin y'all are using a special formula for the Peachy, or is it standard Maker Juice?
04-17-2014, 03:17 PM #54
- Apr 2014
- Fort Collins, Colorado, USA
- 6
Feign,
I just checked and the laser is 405nm. This is known as UVA/VIS as it is at the top of the ultraviolet range and the bottom of the visible range.
Anyway, there are plenty of 405nm laser diodes : http://www.digikey.com/product-highl...er-diodes/3447
04-17-2014, 10:13 PM #55
- Sep 2013
- San Diego
- 210
SubG or SubG+, I can't recall which. But it's just the standard stuff. Cures up to 420nm, it says on the bottle.
04-18-2014, 07:31 AM #56
- Dec 2013
- Georgia
- 934
Well, I'm happy to be corrected like that! My research into photopolymers was clearly incomplete. So this stuff will cure with a regular blacklight (or blacklight LED), then. I'll have to get some of this to see what other things I can do with it while waiting.
04-18-2014, 11:47 AM #57
- Sep 2013
- San Diego
- 210
I am a bit lost. Is 420nm more or less ultraviolet than 405nm?
04-18-2014, 11:56 AM #58
- Nov 2013
- Cambridgeshire UK
- 55
405 is closer to what you would consider UV, 420 is more toward the visible blue/violet spectrum.
04-18-2014, 11:58 AM #59
- Nov 2013
- Cambridgeshire UK
- 55
Visible spectrum vs wavelength (nm) from WikiLast edited by Pete; 04-18-2014 at 12:00 PM. Reason: give the picture a useful description
04-18-2014, 12:54 PM #60
- Sep 2013
- San Diego
- 210
Okay, I should have just looked that up, but thanks for clearing it up. So the resin will cure up to about half of the visible UV spectrum.
