Results 11 to 17 of 17
08-21-2016, 08:19 AM #11
- Aug 2016
09-04-2016, 03:28 PM #12
- Jul 2016
Hi I just got my QIDI TECH X-ONE on Friday there and will be unboxing and setting it tomorrow or Tuesday, would it be possible if you could send me the correct settings for it for the Simplify3D software as I use this software with my other printer, the QIDI TECH 1.
Thank You in advance for the information.
09-04-2016, 04:02 PM #13
- Jun 2016
- Oklahoma
- 904
There really is no specific settings yet for S3D. You can make is work ok but I would stick with the software that comes with the X-ONE for now. It does a decent job.
09-04-2016, 04:17 PM #14
- Jul 2016
Thank you for the quick reply wirlybird .. I will do that, I hope to get it unboxed and setup printing tomorrow if plans work out.
Thanks again
11-18-2017, 07:52 AM #15
I bought one and I'm thrilled with it. I've been using SketchUp 3D to design an enclosure for a NanoPi-based device. SketchUp exports STL files; Cura turns them into G-Code files, which are written to the X-one 2's SD card. There's no requirement for a serial connection between printer and computer. Eventually I'll give Simplify3D a try, but Cura is adequate for the moment. If anyone is interested, I'll write a review. This is my second 3D printer (my first was an M3D). Whereas the M3D took a while to configure, the X-One 2 worked perfectly from the beginning and required no configuration (other than to enter the correct settings in Cura). I was surprised.
11-21-2017, 12:37 PM #16
- Aug 2017
- 95
02-07-2018, 01:03 AM #17
- Feb 2018
I used this printer.
it's very good.
I suggest buying this printer.
You can see my portfolio with this printer here
