Results 1 to 10 of 17
06-18-2017, 10:46 AM #1
- Jun 2017
- 9
One UP steel gear extrusion spillover / problems
Okay I guess I am late to this party and I just got a One UP and assembled it - however when I print the filament 'squirts' out the side of the extruder *even though I feed it completely into the hotend* and the print stops.
It does not seem like a slicer / repetier speed thing as it has happed at 1, and .9 speeds.......
thanks in advance
06-18-2017, 03:23 PM #2
- Jun 2017
- 38
Can you supply some pictures?
06-19-2017, 03:02 PM #3
- Jun 2017
- 9
if you can see (a bit hard because it is black filament) but by the roller on the side of the extruder you can see the filament coming out there
06-19-2017, 03:03 PM #4
- Jun 2017
- 9
google photo's link
https://drive.google.com/file/d/0BxA...ew?usp=sharing
06-19-2017, 04:33 PM #5
- Jun 2017
- 38
What size of nozzle are you using? Little better picture that is closer would help. Swing more around the back too.
06-19-2017, 05:20 PM #6
- Jun 2017
- 9
it is a .4 nozzle - I will take more photos tomorrow sorry about that I took it apart to 'unjam' it as soon as it happens again I will take more photos
06-19-2017, 06:33 PM #7
- Jun 2017
- 38
Don't necessarily need a picture of it jammed, just a good look at the back. Want to make sure there isn't too big of a gap between the feeder and whatever is between it and the hot end.
06-20-2017, 04:13 PM #8
- Jun 2017
- 9
I will try to get an infocus pic (my camera battery just died)
it is about 3/4" from the extruder to the hotend hopefully you can see
06-20-2017, 04:15 PM #9
- Jun 2017
- 9
06-20-2017, 04:23 PM #10
- Jun 2017
- 38
