Results 391 to 396 of 396
12-19-2016, 04:04 PM #391
- Jul 2016
- Pennsylvania, USA
- 255
Hi
Start from a scratch compile, undefine their default display and define the graphics controller. Unless there is a very new bug, it should compile.
Bob
12-19-2016, 05:05 PM #392
- Jul 2014
- 305
I got it working! I found a typo in the following section:
"#define PREHEAT_1_TEMP_HOTEND 180
#define PREHEAT_1_TEMP_BED 70
#define PREHEAT_1_FAN_SPEED 0"
So when it was trying to compile it couldn't match those values with another .h file. All is fixed for now. Thank you!
12-19-2016, 05:12 PM #393
- Jul 2016
- Pennsylvania, USA
- 255
Glad it's working !!!
12-19-2016, 08:09 PM #394
Yes... Your understanding is correct. And incidentally, the BL-Touch stuff was added after UBL forked from RC-7. So you can use a BL-Touch with UBL, but you have to set it up as manually instead of just saying you have a BL-Touch probe. I'm off skiing in Taos. As soon as I get back I'm going to be doing a 3-way merge to get UBL running on top of RC-8. At that point, the simple BL-Touch support will be in UBL also. Realistically, it will be a week or two into January before that happens.
But if you are going to do Mesh Bed Leveling... You really should consider bringing up the UBL system. You will get 100% adhesion across the entire bed every time.
12-24-2016, 09:35 PM #395
- Dec 2016
- 7
I use Sketchup pro to design my models and I just export the STL file into simplifying 3D and boom chicken soup I can create 2 color prints any shape I want really easy if you're interested I have included a link to YouTube showing the process https://youtu.be/TXpJW1RhCA4
12-25-2016, 07:05 AM #396
- Jul 2016
- Pennsylvania, USA
- 255
Hi
The problems come when you have multiple colors (say 4) and they are all present on a layer (think Rubix cube). Unlike simple color change past this layer stuff, that sort of thing is not easily handled at several levels in our existing tool chains. Brewing up 4 interlocking STL's and getting them all set up is the way it's done. Not a lot of fun ....
Bob
