Results 1 to 10 of 12
Thread: CTC prusa i3 extruder update
11-16-2016, 02:14 PM #10
- Nov 2016
- 9
Tonight I found the problem.
The retraction was too long causing the melted plastic to get out of the teflon tube then causing a clog, I changed the retraction from 1mm to 0.5mm
I increased the voltage on the drivers too, without multimeter, I just installed a bigger heatsink on it and increased it by 1/8R and things looks running good.
I just hope the E3D V6lite support I'm printing will be printed well because I really need it to replace the stock hotend, I'll keep you upgarded !!
New member with print issue
