Originally Posted by
OldSourKraut
One mod I did make to the single hexagon shroud was to remove the plastic at the bottom between the hot end and cooling fins and replace it with a piece of brass that is cut to go around the hot end and wrap up the sides, this is attached with a couple of m2 bolts and nuts. This stays cool and avoids the melting plastic issue. Looks like I'll be doing the same to the double shroud as well.
Thanks for all the time and effort you have put into this project.
