11-23-2017, 09:53 AM #1
- Nov 2017
Printing with TPU flexible filament
So i've got a monoprice selectmini and i've been fighting with this flexible filament for about a week, I can't figure it out.
my print looks like this:
When it should look like this:
I've printed it at many settings but that one was printed at 250 celsius and 30 mm/s
help!
11-24-2017, 06:35 AM #2
way way way too fast.
Also probably too hot.
Even on a good flexibles printer, you'll not get a decent print from a soft tpu at anything much over 10mm/s
Also doesn't hurt to up the extrusion to 110-120%
And make sure your retraction is fairly short. 1.8-2mm.
But primarily, you're printing much too fast. Which is why the rubber has been deposited if fits and starts.
Which brand tpu is it ?
One way to fix this would be to buy some polyflex flexible pla.
Not the cheapest but brilliant stuff for printing with.
But going much slower with a bit more extrusion should also sort it.
11-27-2017, 07:11 AM #3
- Jul 2017
- 184
I agree with CA, too fast. Flexibles generally don't print well (if at all) at regular print speeds. As well as lowering retraction, maybe turn it off entirely. Try a range of print temperatures too.
Last but certainly not least, can you show us your extruder? Most extruders have a gap between the drive gear and where the filament enters the hotend, flexible filament tends to buckle in this area.
It might also be worth checking if your hotend is a bit (not fully) clogged or jammed, as flexibles seem a bit more sensitive to resistance to flow in the hotend because of the aforementioned buckling issue.
05-14-2018, 02:54 AM #4
- May 2016
- 14
Speed is so fast. Printing with Tpu/tpe is different from PLA/ABS, you should slow and low printed temperature.
Newbie Question
Today, 12:02 AM in Tips, Tricks and Tech Help
