  1. #1
    CR-10 nozzle heating
    I just got a CR-10 and I'm trying to get it setup. I can't set the level because it came with a little bit of plastic (PLA I assume) protruding from the nozzle. I want to try the Atomic method to remove it, but I can't get the nozzle to heat.
    I select control/temperature/nozzle then turn the dial to 220, but nothing happens and after a short time the screen goes back to the home page.
    Can anyone suggest how I can get the nozzle to heat?
  2. #2
    Jul 2014
    check you've got your wires properly connected, sounds like it's not getting the instructions from the panel.
    Have you tried heating it from the slicer via usb connection ?
    Just a good way to double check.
  3. #3
    The wiring is all well labeled plug n play. But I did already have a small issue with the Z limit switch. I'll open the box and give it a good check. I don't have anything but the Cura software loaded yet, but I'll get Slicer and try that after I've checked the wiring.
    Thanks
  4. #4
    Jul 2014
    lol cura IS the slicer.
    Slicer is a just a term for the software that slices your stl files :-)
    Cura will let you control the printer from the printer control panel.
    See if it works from there.
