Results 61 to 70 of 73
Thread: Diy it?
Hybrid View
07-04-2016, 01:33 PM #1
- Sep 2013
- 308
Acrylic works and its is what we original planed to make printers with.. abs is better because acrylic often breaks on the fine snap fit tabs, but it still works
and a bit of hot glue can solve any problems you have with it. I think that 1/8 inch birch plywood would also work and so would petg. petg would be the strongest.
We have been doing the parts in 3mm thick plastic but because we designed in openScad it should be relatively easy to cut parts from other thicknesses
try playing with the SheetThickness variable in the openSCad files.
Sorry Im not in here answering more questions right now.. Im in the middle of moving, so I spending lots of time boxing and cleaning, loading trucks etc.
06-08-2016, 02:30 AM #2
- Oct 2013
- nsw australia
- 81
@thej, it should work assuming you have a sheet at approx the right thickness (I think I had measured it at approx 3mm thick), and the gasses released are part of the issue with the FFF printers and abs also
06-08-2016, 01:09 PM #3
- Jul 2014
- BC Canada
- 20
I'm still trying to find the most current version of the structural pieces in the git repository.
I printed the "all.dxf" file on the laser cutter last night and when I compared them to the assembly animation Rylan posted (page 3 of this thread), they are NOT the same!! These are possibly the "oil dampened version" as discussed in this thread.
In "PeachyPrinterHardware/peachy_production/" these files here appear to be the scanner.
In "PeachyPrinterHardware/peachy_printer/ there is a collection of SMC files that COULD be the right files but I can't open them to verify.
I know these SMC files were created by the Laser Cutter's software but what is that software and can I download it?? (Ok, Duh, it's "SmartCarve")
Are there DXF versions of these files somewhere?
Has someone found the most current files?
The laser cutter at my local MakerSpace uses RD Works (I'll be getting a copy soon). This outputs RDL files not SMC. I can not open them with RD Works :-(
helpLast edited by thej; 06-08-2016 at 01:21 PM. Reason: update
06-09-2016, 01:16 PM #4
- May 2014
- 60
Hey there, that repo is all old stuff, you want this one: https://github.com/PeachyPrinter/pea...terhardware1.0
Totally threw me for a loop at first to!
MOST of the items have .scad files for them. This is a format used by OpenSCAD, it's really just a text file containing a script that defines the object. I'm not sure about converting this to RD Works, I do know that it can output at least a .stl file.Last edited by oninoshiko; 06-09-2016 at 01:25 PM.
06-09-2016, 03:13 PM #5
- Jul 2014
- BC Canada
- 20
Thanks! I dug through those files before but I really didn't know what I was doing yet ! I will check them out again :-)
RD Works will take a DXF so converting the SCAD models to DXF will work just fine.
J
06-14-2016, 11:22 AM #6
- Mar 2016
- 68
Please read carefully what I typed before: it is a combination of factors: cost (laser diode prices increase substantially as they become more powerful, goal was a sub C$100 printer), curing time (the resin curetime is the main determining factor) and accuracy (if it takes x seconds to cure a layer either way, move slower as it increases accuracy)...
06-14-2016, 11:35 AM #7
- May 2014
- 4
Is there a datasheet for the resin?
06-22-2016, 08:03 PM #8
- Sep 2013
- Saskatchewan, Canada
- 294
You'd probably want to contact makerjuce for that kind of info, as they were the ones making the peachy resin.
https://www.makerjuice.com/pages/contact-us
06-23-2016, 08:27 PM #9
Can't speak to what was used with the later stuff, but for the beta users it was "PeachyJuice Stiff or MakerJuice SubG/SubG+ resin". I got Stiff in the beta shipment.
You can search the internet for the Makerjuice SubG/SubG+ MSDS sheets - what I just tried is a little different but I can't seem to upload it due to the file size (197 kb). probably not current anyway, it was from 2014.
06-14-2016, 11:41 AM #10
- Mar 2016
- 68
05-13-2024, 03:08 PM in 3D Printer Parts, Filament & Materials
