Results 2,901 to 2,910 of 4110
08-21-2016, 05:19 PM #2901
- Aug 2016
- 11
Very nice. Did you fit the nut in during or post?
I see you have the Flexion extruders on in that pic - is it an older one?
08-21-2016, 05:49 PM #2902
- Jun 2016
- Oklahoma
- 904
08-21-2016, 11:27 PM #2903
- Mar 2016
- 29
08-22-2016, 02:17 PM #2904
- Jun 2016
- Oklahoma
- 904
Anyone tried Hatchbox PLA or ABS? What do you think?
08-22-2016, 03:26 PM #2905
Hatchbox and ESun are both well respected and popular brands. Both there ABS and PLA work fine for me.
I use either depending on price and availability on Amazon Prime.
08-22-2016, 06:12 PM #2906
- Jun 2016
- 21
08-22-2016, 06:40 PM #2907
- Jun 2016
- Oklahoma
- 904
QIDI TEch-1 extruder temp issue. My printer seems to have developed an issue maintaining the extruder temp. Say I set it at 200 for a print. It heats ok but a little while after the print has started the temp registers as much as 15 degrees less. S3D and the printer display both agree. After a long time, let's say 20 minutes into the hour and a half print the temp slowly starts to inch up. Over the 90 minutes the temp is barely able to get back to the target temp.
Any ideas?
08-22-2016, 06:50 PM #2908
- May 2016
- 55
I had this problem when the big side fan was on. Once the unused extruder reaches 50°, there are three fans running and the extruder you're using has a hard time maintaining its temperature. Making sure that side fan is off, if you haven't already, should be your first step. I disconnected the cable to make absolutely sure.
08-22-2016, 06:54 PM #2909
- Jun 2016
- Oklahoma
- 904
My new design for the rear manifold for my dry box. It keeps the original part for the two rolls on the back of the machine without restricting access and adds for the five feeders from my dry box. Now, when I can remove the filament I am running I will install and see if it really works.
[IMG][/IMG][IMG][/IMG]
08-22-2016, 06:58 PM #2910
- Jun 2016
- Oklahoma
- 904
I see what you are saying but it doesn't even try to reheat. It can take twenty minutes before it decides to start heating or atleast it isn't indicating it is heating.
Also I need the fan for PLA. When I was using the right extruder I was having issues with extruded filament overheating or not cooling sufficiently especially toward the rear of the printer.
I'll git it a shot thought to see if that does affect it.
Thanks for the suggestion.
