Results 1 to 10 of 10
01-17-2014, 06:17 AM #1
- 35
Looking for very small nozzle (<0.1mm) - would it work?
Where would I be able to find a very small nozzle that is smaller than or equal to 0.1mm?
Also does anyone know what the minimum size is for filament to fit through?
01-17-2014, 07:51 AM #2
- new jersey
- 752
smallest i have seen is a .25. they can get a little tricky to print with. you wont find a .1 that i know of. the problem is that the plastic is thick and the force necessary to squeeze it through such a small hole become more than what a drive gear can put on the filament without stripping out.
01-17-2014, 01:34 PM #3
So far i know its 0.2
And not many make those,
The smallest you generaly can easyer find is 0.25.
01-17-2014, 02:23 PM #4
- Honolulu, HI
- 199
Here is a link to a post on small nozzles on another forum: http://www.printrbottalk.com/forum/v...+nozzle#p39371
Pretty cool stuff!
01-17-2014, 04:16 PM #5
- new jersey
- 752
i bookmarked that. long thread but looks interesting. thanks for the link
01-18-2014, 07:38 AM #6
I could have sworn I saw someone using a 0.15mm nozzle. I think if you go any smaller than that, you will run into problems with the filament not making it through.
01-16-2016, 07:12 AM #7
- Jan 2016
Hi,
dont know if this thread is dead... maybe this post will bring it back to life.
I invented a new type of cold end, it does not use a hobbed bolt but a belt. I hope it will inspire a whole new type of extruders, called v-struders
One of my first customers, a goldsmid, has let me know that he was able to print without any problems with a 0.1mm nozzle using moldlay wax filament. Im now searching for a place to buy a 0.1mm nozzle or even smaller so I can confirm this myself. Anyone knows a good webshop, preferably with fast shipping?
To this moment I was only able to test the v-struder with a 0.4mm E3D nozzle. In an extrusion only test, using petg 1.75mm at 235 degrees celcius I was able to extrude up to 2 meters per minute of raw filament without any slip in a bowden configuration with a bowden tube of 1 meter long.
You can buy it here: https://reprapworld.com/?products_de...8#.Vpo9WlKGNoc
Happy printing,
Vaeder
01-18-2016, 02:38 AM #8
Try and buy one un-drilled and have it custom-drilled yourself ?
01-19-2016, 04:17 PM #9
- Jan 2016
I have a 0.2mm nozzle and Ive found some ABS will not extrude through it
07-27-2016, 04:20 AM #10
I bought a 3D printer online and it's extruder is changeable into different nozzle printheads like 0.2, 0.3, 0.4, 0.5, 0.6, 0.8, and 1.0mm. And I think they are also selling a 0.1mm nozzle extruder. Check out their Novio 3D printer online shop.
