Results 11 to 20 of 42
Thread: so what causes this?
01-20-2015, 07:35 PM #11
But isn't there a risk that you can get too tight on the belts? That was part of the basis about it being hard to get the right tension - that you want enough but not too much. And again, my belts are now tighter than ever, but I can't say that's made a difference.
Remember that the ringing effect is showing up when the printer has only moved a millimeter or less in the lateral axis. Acceleration and deceleration should have kept the speed for that small of a distance pretty low, at least in the meager bit I understand Marlin move planning. Again - I can understand ringing on major 90 degree corners, but not so easily on cases like shallow recesses for lettering or holes on thin walls.
My four-sided ringing test print is complete. First, I realized that the case I printed yesterday had small radius rounded corners, so not having ringing there is no surprise. The test object had an identical notch and round hole on all four sides of a cube. Pretty equal ringing on all four sides. I'm not sure pictures will reveal details well, but I may try to take some in the morning.
01-20-2015, 07:47 PM #12
For Our Y tension I slotted the bearing end and add two eye bolts through the frame to the bearing attach screw.
01-20-2015, 08:12 PM #13
01-20-2015, 08:21 PM #14
- Jul 2014
- Ontario, Canada
- 257
Printbus, you raise a good question. I have always wondered if mine are too tight or not enough, with finding very few actual answers online.
I know that on my y axis, making the belt any tighter starts to warp the rear y bracket, to me that's too tight then. Both my belts are tight, and produce a very low "sprung" noise when plucked, but I always wonder if they could be better!
01-20-2015, 08:34 PM #15
OK - just ran another of my test prints. XY jerk set to 2 (effectively allowing no jerk). Overall acceleration set to 400. Top speed in Simplify 3D 70 mm/sec. On the cube, everything is a perimeter, so printing is going at best half that. Still getting a lot of the artifacts around the holes and notches. Something definitely other than mechanical ringing is involved IMO. Mechanical ringing might be part of it, but it's not the whole story.
EDIT: It's almost as if what is really happening is temperature of the extruded filament varying a bit as the extruder slows down and speeds back up.Last edited by printbus; 01-20-2015 at 08:52 PM.
01-20-2015, 08:34 PM #16
- Jul 2014
- Eastern Colorado
- 536
As far as I know nobody's come up with a universal metric for determining "proper" belt tension. I did find one tool for measuring tension on Thingiverse, but I've not tried it yet.
01-20-2015, 08:56 PM #17
01-20-2015, 09:00 PM #18
01-20-2015, 09:11 PM #19
Vacillation of the pressure in the hot end comes to mind as well.
01-21-2015, 06:39 AM #20
- Jul 2014
- Eastern Colorado
- 536
Do you see ringing on the inside of the box as well? That's what I would expect if it had something to do with the extruder.
05-13-2024, 03:08 PM in 3D Printer Parts, Filament & Materials
