Results 1 to 10 of 53
05-30-2015, 12:14 PM #1
- May 2015
- 15
So elsewhere I was reading about the possible problems with surface tension in the resin and how heating it may be a way to lower the viscosity and hence the surface tension. How about simply adding something simple, like say an aquarium heater to the salt water storage tank? By heating the water you will raise the temp of the resin as well, and have a steady supply of fresh heat entering the system to keep temps stable. The heaters are limited in range, so that overheating should not be an issue.
05-31-2015, 12:20 PM #2
- May 2015
- 43
I like the idea (the surface tension issue has been bothering me) but I feel once the water gets from the top tank to the bottom it will have lost most of it's heat.
Maybe a beer warming matt or even a USB cup warmer?
06-01-2015, 03:29 PM #3
- May 2015
- 15
I really don't think there would be much heat loss there. We are using nylon tubing normally, which has a low thermal conductivity and fairly fast flow rates. I do agree that finding a way to heat the build tank would be much better, just looking for the simple, quick and cheap fix here.
06-01-2015, 03:51 PM #4
- May 2015
- 43
