Results 1 to 10 of 29
Thread: ABS Not Sticking to Bed
04-28-2016, 03:12 AM #1
- Apr 2016
You will want the bed at 110C once the print has started. I start with 75C then ramp up to 110C after the bottom layer in order to reduce waiting times for the bed to heat up. So that's your first problem. Nozzle temperature should not affect bed adhesion.
Was that a mis-type, and did you mean "diluted ABS"?
04-28-2016, 03:17 AM #2
04-28-2016, 03:51 AM #3
- Feb 2016
- 68
Hi iDig3Dprinting
I am inn the process of changing back to PLA to do a few things. I could not push through the PLA but must have been I did not have the new PLA lined up with the hole. So I pulled the head apart but it was easy to push through the ABS.
The ABS kept bending up from the ends at the 100-110 and it was mentioned to try the 75 degrees for the first few layers. I'll get back to ABS sometime soon but will try PLA for a while.
Wondered if I could just put glass on my bed and what thickness glass if you are you are using glass. Mine is a Cocoon Printer (Wanhao Duplicator i3).
04-28-2016, 09:26 PM #4
- Feb 2016
- 68
Seeing I am only new to the 3D printing it is good to see the PLA works great.
04-28-2016, 03:43 AM #5
- Feb 2016
- 68
