Results 1 to 10 of 52
01-07-2016, 05:33 AM #1
The main problem is that there is no such thing as 'pla'. There are several hundred hundred different materials - all with different specifications and properties that are called 'pla'.
So while abs - is pretty much just abs - there are variations that warp less, have higher temperature usages etc - but compared to pla - damn few of them.
So while the pla you got 5-10 years ago was fairly limited - today you can get a pla based filament with just about any properties you like.
There are pla filaments that outperform abs in all properties. there are bendy pla's. hi-temp plas, conductive, carbon fibre reinforced.
So one thing to instantly dismiss when comparing abs and pla is the myth that pla is brittle, shatters or in any way weaker than abs. It's not, if you buy the right pla :-)
The main differences are fairly simple.
pros:
1) abs is cheap and has good mechanical properties.
2) you can use acetone to make it smooth and pretty.
cons:
1) unless printed in a fully heated enclosure - warps like a bastard.
2) you pretty much end up breathing in a lot of acetone fumes.
3) makes your workshop smell like burning plastic
4) can be tricky to make stick to print surfaces.
pla.
Pros:
1) very easy to print with, warping varies from none to a tiny amount.
2) will stick to just about any print surface
3) so many types around that there will be one that does what you want it to
4) good general prupose pla is cheap.
50 no real smell when printing.
cons:
1) specialist pla filaments can be pricey, although flexible pla is cheaper than tpu (polyurethane based) flexible filaments and much much easier to use
The point is that abs is a long standing plastic that was developed for injection moulding. Whereas todays pla filaments have been specifically developed just for 3d printing.
01-07-2016, 10:45 AM #2
I would add a few things to this list:
This is absolutely untrue. PLA has been around since the 1930's (if I recall correctly it was developed by DuPont in 1932) and is used extensively in injection moulding particularly in the food packaging industry (yoghurt tubs, etc) and also disposable cutlery and plates (like camping gear).
01-08-2016, 08:21 AM #3
4) can be tricky to make stick to print surfaces. Absolutely not true
Not sure what fairy dust you use to make this not true. It's unfortunately very true for most folks that try ABS 3D printing.
01-07-2016, 02:36 PM #4
I Print almost exclusively with ABS, and while it's slightly more tricky to work with than simple plain Jane PLA, it's not nearly as difficult as some of the specialty PLA's (from what I've been reading). From my experience with ABS, I would almost go as far as saying all your ABS cons are grasping at straws, with maybe #1 being the exception. While it's not impossible to keep small ABS objects from warping without an enclosure, it does make it easier.
All that said, I do suspect there are many PLA filaments out now with much better characteristics than ABS, but man some of those filaments are crazy expensive, and ABS is cheap for strength.
05-04-2016, 04:03 PM #5
- May 2016
- SE Wisconsin
- 206
Polyester is a polymer as well. All plastics are polymers. It's just one subcategory.
And continuing on the late to the party trend:
There are currently 6,106 results for 'ABS' in the materials database I use, many are base resins with different fillers (glass, minerals, lubricants, etc) and multiple manufacturers are listed which may have the exact same chemical makeup, so I could very conservatively estimate close to a thousand unique additive formulations.
Afterall, the additives define most of your processing parameters.Last edited by Ama-fessional Molder; 05-06-2016 at 07:04 AM.
