Results 1 to 10 of 16
Thread: QIDI 1 surging fan
09-25-2016, 02:26 AM #1
- Sep 2016
- 7
You said there are hot end fan speed settings in Simplify3D. This I know. They do not, however, apply to the turbo fan. It's either on or off. The hot end fans run fine making it unlikely to be a PS issue.
09-25-2016, 02:25 PM #2
I don't see where I specified hot end anyways but here is a screen shot where you can adjust the settings of the AUX fan.
As you see here I have it at two different speeds, one for the first layer and another for the rest. You can make it do more as you see with the settings.
Editor in Chief
Bitsonline
09-26-2016, 10:47 PM #3
- May 2016
- Annapolis, MD
- 523
Unfortunately, the QiDi printer does not respond to the fan/blower/aux speed setting other than to be either on or off. S3D does allow one to set the "fan speed" by layer, but my understanding is that there is no compatible "X3G" command to set the fan speed, so the QiDi just turns the fan on full, or off as a compromise.
09-27-2016, 12:16 AM #4Editor in Chief
Bitsonline
09-29-2016, 12:01 AM #5
- Sep 2016
- 7
Reality Check (back to the thread topic)
1. Answer to my first original question:
The aux cooling fan plug near the extruders was defective. At rest it worked but when jerked around by the head in certain directions the fan power was intermittent. Fixed.
2. Answer to my second original question:
The code to turn on the aux cooling fan is M106. The code to turn it off is M106 S0.
(END OF THREAD)
09-29-2016, 01:12 AM #6
No need to be rude.
Educate yourself.
Glad you found the issue with the fan.
For the fan issue in the file itself as I stated and posted a screen shot for you, Simply 3D allows you to control the fan speed layer by layer of you want.
I setup OctoPrint on an RPi (hence the name OctoPi) and send my files to be printed directly to the printer through that instead of the SD card route.
It does not like the x3g files and instead uses the gcode files. S3D has the ability to save both the x3g and the gcode file at the same time.
Fan on/off and speed settings work on the gcode file. The x3g its either on or off. I've not looked into seeing if you can pack the speed control in the x3g file.
Glad your up and running again. Enjoy.
Editor in Chief
Bitsonline
09-29-2016, 07:27 PM #7
- Sep 2016
- 7
09-30-2016, 11:04 AM #8
Time for everybody to just back away from this one...
- Moderator
