Results 11 to 20 of 20
Thread: Advice on my watercooling setup
12-16-2014, 11:22 AM #11
- May 2014
- 100
That makes sense. You don't happen to have an squirrel cage fan recommendations do you? haha
12-16-2014, 11:38 AM #12
- New York
- 66
http://lmgtfy.com/?q=squirrel+cage+fan
Funny you mention it, sunon and delta fans are good quality. Look for one with liquid filled bearings and not bushings.
12-16-2014, 11:42 AM #13
- May 2014
- 100
Oh psch, you could have easily skipped the lmgtfy. haha
12-16-2014, 03:06 PM #14
- Honolulu, HI
- 199
I don't think you will have any problem with standard pc water cooling parts. The pump that I use on my pc has been working for several years now without any hickups. I also wouldn't think you'll have any problems with standard tygon tubing with the amount of flexing you will be doing. I use this in my work and have never had any failures. It is plenty flexible and will be fine. One thing though - you are always taking a chance with water cooling and its close proximity to electronics. Keep this in mind when you are working on the design.
12-16-2014, 03:47 PM #15
- Dec 2013
- 8
12-16-2014, 04:50 PM #16
- Burnley, UK
- 1,662
12-16-2014, 04:57 PM #17
- Dec 2013
- 8
Is that speaking from experience or a personal hypothesis?
Stratasys printers don't have a heated bed, so you'll have trouble printing PLA on them - either you'll have to heat the chamber and the hotend will jam, or you'll have to print on a cold bed and you'll get part warp.
PLA has a Tg of 60C, which is where you'd want to set the heated bed (but you can't, and setting the build environment to the polymer's Tg = jammed hotend)
12-16-2014, 05:15 PM #18
- Burnley, UK
- 1,662
Speaking from experience. I have only printed PLA once and it was with the Stratasys. I bought 25 metres just to see if it would print OK. I don't use PLA as I prefer ABS but had to try it.
The bed is heated by the chamber. It is not possible to have a cold bed and a heated chamber unless you have refrigeration plant on the bed.
Suggest you buy a Stratasys and try it.
A significant number of people use PLA in place of the Stratasys support material as it is cheap and will dissolve in D-limonene.
12-16-2014, 05:30 PM #19
- Dec 2013
- 8
IF heated chamber = cold THEN bed = cold AND part = warped
IF heated chamber = warm THEN bed = warm AND hotend = jammed
That was my point. Never said anything about making the heated chamber warm and the bed cold. What temperature did you set the build environment to?
You say "a significant number", but I cannot find any examples on Google. Do you have any examples?
"Suggest you drop $20k and try it" is hardly helpful.
12-16-2014, 11:30 PM #20
- Burnley, UK
- 1,662
