Results 1 to 10 of 172
10-31-2014, 11:20 PM #1
- Jul 2014
- Eastern Colorado
- 536
I've made some changes in case someone decides to add this code to Marlin, but not enable it:
case 28: //G28 Home all Axis one at a time
#ifdef ENABLE_AUTO_BED_LEVELING
#ifndef SAVE_G29_CORRECTION_MATRIX
plan_bed_level_matrix.set_to_identity(); //Reset the plane ("erase" all leveling data)
#endif
#endif //ENABLE_AUTO_BED_LEVELING
#if Z_MIN_PIN == -1
#error "You must have a Z_MIN endstop in order to enable Auto Bed Leveling feature!!! Z_MIN_PIN must point to a valid hardware pin."
#endif
#ifdef SAVE_G29_CORRECTION_MATRIX
#endif
This way G28's original function of erasing the matrix is retained while the code is disabled, and then switched to G29 when it is enabled.
11-01-2014, 01:13 AM #2
- Aug 2014
- 627
No, NO, N O!!! This just means in a case like mine because I can tell you that today my matrix will look like A and tomorrow the matrix will look like C and the next day B=A+/-C so in my case I would never ever just use the same matrix all of the time. One print then another (as in my example) I might (I have not tried it yet but theoretically it should be fine) but never from one day, or even hour, to the next. Basically if the bed has had a chance to cool completely down, as well as the entire printer, forget using a previous matrix.
11-01-2014, 08:52 AM #3
11-01-2014, 12:59 PM #4
- Aug 2014
- 627
Nope, heat makes it flex and the parts expand and when it cools down, plus the movements of the bed while it is warm, makes the parts change ever so slightly.
To see if your printer will work do a G28/G29 U 6 T with everything heated up. Now go do a print of something like normal. Let it all cool down and in 1 hour come back to a nice room temp printer. Now with the complete printer sitting there at room temp go heat up the hotend and bed then do a g28/g29 U 6 T and see if the numbers are exactly the same. If they are then you have a golden printer and should never need to do another G28/G29 again.
11-01-2014, 01:28 PM #5
- Jul 2014
- Eastern Colorado
- 536
So you think nobody should ever use this code?
11-01-2014, 02:07 PM #6
11-01-2014, 03:50 PM #7
- Aug 2014
- 627
Exactly what I was getting at, or trying to say, AbuMaia.
For most people, not the lucky few, this routine will mean they can print in multiple colors in one session with a single extruder but once that printer cools down and you have to reheat it those people, the majority of the people that includes me, and apparently Roxy is among us, we *must* reissue the G28/G29 again.
11-01-2014, 08:45 AM #8
Yeah, I was kind of torn which way to go. Doing what you did preserves the original behavior which has merit. It might be worth a quick discussion to decide if those extra #ifdef's should be added to the first post or not. Personally... I think the correction matrix should start off at Unity and not be affected by the G28. But there is so much legacy in place now that it isn't good to change things for no reason. I decided to make the changes as minimalistic as possible (which meant not adding the extra pre-processor commands). However, with that said, nobody is going to be typing that stuff in anyway. They are going to Cut & Paste it into their source, so there isn't any extra pain involved.
So should we alter the original post? If we do, and SAVE_G29_CORRECTION_MATRIX is not defined, everything will function the same as it used to behave.Last edited by Roxy; 11-01-2014 at 08:50 AM.
11-01-2014, 11:38 AM #9
- Jul 2014
- Eastern Colorado
- 536
Only if you think there's a chance this code might eventually get pulled into the fork or "official" Marlin. As it is now, if someone wants to use it, they'll copy it in as it stands. My changes were for those who wanted to add the code, but not use it. A pretty small population I'd think.
I should have noticed the missing ;. I'm in the middle of a print right now, so I'll test how it prints out the matrix later.Last edited by AbuMaia; 11-01-2014 at 11:44 AM.
